lcs: How to update the WinRM SSL certificate on environments deployed in your subscription
Источник: https://blogs.msdn.microsoft.com/lcs...-subscription/
============== For environments deployed in your subscription that are not managed by Microsoft, the WinRM SSL certificate will expire one year from the date the environment was deployed. If your WinRM SSL certificate has expired, you will see the following error message when rotating secrets using the Maintain > Rotate Secrets through Lifecycle Services. You can... Источник: https://blogs.msdn.microsoft.com/lcs...-subscription/
