Старый 08.06.2017, 21:11   #1
stoneridgesoftware: Extension Model: Creating a Static Table Method in Dynamics 365 for Operations
Источник: https://stoneridgesoftware.com/exten...or-operations/
Creating table static methods for some tables was straight forward prior to the release of Microsoft Dynamics 365 for Operations (AX7), and arguably it still is if you are overlaying. Although this article is not intended to distinguish between over layering and extensions, I feel it is important enough to include some key points in this post.
Creating table methods that are static, while using the extension model are a little different. In this scenario, I will create a new method to validate that there is an entry in the external comment field in the table: TSTimeSheetLineWeek.
static class TSTimesheetLineWeek_Extension { /// /// Don't forget your comments /// /// /// Don't forget your comments /// /// /// Don't forget your comments /// public static boolean validateExtNotes(TSTimesheetLineWeek _tstTimeSheetLineWeek) { int i; boolean ret = true; for(i = 1; i
stoneridgesoftware: Relevance Search Dynamics 365 for Sales (CRM) Blog bot Dynamics CRM: Blogs 0 22.04.2017 02:26
stephenmann: Technical History of Dynamics AX - From Axapta 3.0 to AX2012 Blog bot DAX Blogs 5 03.03.2017 10:22
atinkerersnotebook: Creating New Customer Notifications for Dynamics 365 for Operations using Flow and the Common Data Service Blog bot DAX Blogs 0 15.12.2016 22:12
stoneridgesoftware: Creating a Default Lookup Form with Filter in Dynamics AX Blog bot DAX Blogs 0 29.07.2016 02:37
stoneridgesoftware: Dynamics 365 and Microsoft AppSource – What does it mean for clients? Blog bot DAX Blogs 0 14.07.2016 01:14
Часовой пояс GMT +3, время: 06:03.
