palleagermark: Use tags to find related bits and pieces in your code base
Источник: http://www.agermark.com/2017/05/use-...-bits-and.html
============== A lot of elements, if not all, in Dynamics 365 for Operations (D365FO) has a property called "Tags". With this property you can link all sorts of different otherwise unrelated elements. You could for example use this as part of a bigger change you need to do to your code base, marking all the bits you need to modify. Adding a tag is as simple as just using it: For Visual Studio to find places where the tag is used, you need to do a build with the "Build cross reference data" option checked: And here is where you search for tags: And here is the result: This ought to work for code to. The editor knows about the tags and has intellisense for them: But the "Find tag references" tool doesn't pick them up. I wonder if that is a bug or not. And in my opinion you should try to not go overboard tagging away all day long. Источник: http://www.agermark.com/2017/05/use-...-bits-and.html
