dynamicsaxhints: How to copy cross-reference from one environment to another
Источник: http://dynamicsaxhints.blogspot.com/...-from-one.html
============== Cross-reference is a very useful tool in Dynamics AX, but cross-reference update requires a lot of time and resources. I want to share a simple way to copy cross-reference data. Problem description Copy cross-reference from one development environment to another, provided environments are identical. Hints Use bcp utility for export and import. Solution Cross-reference tables contain a lot of data, for example standard application with minor modifications in AX 2012 CU8: XREFNAMES: 1.25 million records, 500MB space XREFPATHS: 2.46 million records, 1400MB space XREFREFERENCES: 14.35 million records, 6500MB space Export The following bat file can be used to export XREF* tables: bcp MicrosoftDynamicsAX.dbo.XREFNAMES out XREFNAMES.txt -c -T bcp MicrosoftDynamicsAX.dbo.XREFPATHS out XREFPATHS.txt -c -T bcp MicrosoftDynamicsAX.dbo.XREFREFERENCES out XREFREFERENCES.txt -c -T bcp MicrosoftDynamicsAX.dbo.XREFTABLERELATION out XREFTABLERELATION.txt -c -T Where: - MicrosoftDynamicsAX is Dynamics AX database name - argument -c performs the operation using a character data type - argument -T specifies that the bcp utility connects to SQL Server with a trusted connection using integrated security. Export took 2 minutes, 4 *.txt files were created in the same folder: Import All records in XREF* tables must be deleted in destination database before import: TRUNCATE TABLE XREFNAMES TRUNCATE TABLE XREFPATHS TRUNCATE TABLE XREFREFERENCES TRUNCATE TABLE XREFTABLERELATION The following bat file can be used to import XREF* tables: bcp MicrosoftDynamicsAX.dbo.XREFNAMES in XREFNAMES.txt -c -T bcp MicrosoftDynamicsAX.dbo.XREFPATHS in XREFPATHS.txt -c -T bcp MicrosoftDynamicsAX.dbo.XREFREFERENCES in XREFREFERENCES.txt -c -T bcp MicrosoftDynamicsAX.dbo.XREFTABLERELATION in XREFTABLERELATION.txt -c -T Import took about 10 minutes. Conclusion Cross-reference can be copied in approximately 15 minutes from one development environment to another. Источник: http://dynamicsaxhints.blogspot.com/...-from-one.html
