Старый 08.06.2016, 03:17   #1
waldo: Invoke-NAVSQL: Execute SQL queries on NAV databases with PowerShell
Источник: http://dynamicsuser.net/nav/b/waldo/...ith-powershell
Just another CmdLet to bother you with (no really, it’s quite an interesting one – try to keep awake … ;-)).
The more you use PowerShell .. and the more you use it for NAV .. you just realize that you have to call out to SQL Server quite regularly. Just a few examples:
  • Backup and restore – Get the default restore directories
  • Update/select the UidOffSet
  • Unlocking all objects while upgrading
  • Granting service user db-owner access
  • … (and a lot more…)
Some time ago, I have been spending time in making the call to an NAV database a little bit simpler from PowerShell.
Goals
Simplicity is key here – I just want to provide a ServerInstance, and the function needs to figure out how to connect to the database. Next, if I had some kind of “select” statement, it needed to be simple to get to the data. As you know, PowerShell returns Objects .. so in case of this new function, columns needed to be properties, and records needed to be elements in my resulting object collection.
Invoke-NAVSQL
I decided to call the function “Invoke-NAVSQL” – according to a similar existing function part of the SQLPS module. You can find the function on my github.
A few major things that stand out in the script:
  • First of all, it is going to get all details from the Server Instance, which it needs to figure out on which database details it has to execute the SQL command. I do this with Get-NAVServerInstanceDetails (also part of my github module).
  • I use quite a default way (.Net) to connect to the database and execute the query to get back a dataset. In my understanding, this way of working with SQL Server is not dependent of any modules, but it just going to use the libraries in .Net – which makes the function somewhat more independent. But I could be wrong (comments always appreciated ;-)).
  • At the end, I’m converting the dataset to a collection of objects, where all fields are properties.
So, if the SQLCommand was a SELECT, this function returns you a clear and user friendly object model.
Some examples
To have a look at the UidOffSet property of our database that is attached to server instance “DynamicsNAV90”:
$dbproperties = Invoke-NAVSql -ServerInstance 'dynamicsNAV90' -SQLCommand 'Select * From [$ndo$dbproperty]'$dbproperties.uidoffsetGet all companies, and get the customers of the first company:
$Mycompanies = Invoke-NAVSql -ServerInstance 'dynamicsNAV90' -SQLCommand 'Select * From Company'$Customers = $Mycompanies | select -First 1 | foreach{ Invoke-NAVSQL -ServerInstance 'dynamicsNAV90' -SQLCommand "select * from [$($_.Name)$('$Customer')]" -ShowWriteHost }$Customers | select 'No_', Name, 'Credit Limit (LCY)' | Format-Table -AutoSizeAssumptions
I know .. “Assumption is the mother of all fuckups“. But simplicity often comes with a number of assumptions, doesn’t it? ;-). My big assumption is the security-part. Namely, I assume the PowerShell user (Windows Authentication) has got access to the SQL Server, and obviously enough permissions to perform the query.
NAV Team: Using Windows Powershell cmdlets to modify companies and databases Blog bot Dynamics CRM: Blogs 0 20.02.2015 17:00
NAV Team: Windows PowerShell and Dynamics NAV for your coffee break - Deploy Dynamics NAV via Windows PowerShell Blog bot Dynamics CRM: Blogs 0 13.02.2015 12:00
NAV Team: How to: Set up your Microsoft Dynamics NAV installation for Single Sign-on with Office 365 using Windows PowerShell Blog bot Dynamics CRM: Blogs 0 19.12.2013 15:10
NAV Team: Validating Single Sign-on with Office 365 and Microsoft Dynamics NAV 2013 R2 Blog bot Dynamics CRM: Blogs 0 19.12.2013 15:00
NAV Sustained Engineering Team Blog: Modern NAV/SQL troubleshooting Blog bot Dynamics CRM: Blogs 0 12.05.2008 14:35
Часовой пояс GMT +3, время: 19:26.
