Periodically we receive support requests about XMLport errors, which really are missing features in xmlport's functionality.
However most of these requests are rejected because: xmlports are not supposed to fulfill all possible xml standard scenarios. So there always will be xml file which can't be created or readed by NAV xmlport. Possible workaround could be to use XML DOM automations. Create it by codeunit: ---------------------------------------- OBJECT Codeunit 50052 xml create { OBJECT-PROPERTIES { Date=03/24/10; Time=[ 1:33:31 PM]; Modified=Yes; Version List=; } PROPERTIES { OnRun=BEGIN CREATE(xmlDoc); xmlMgt.SetNormalCase; xmlProcessingInst:=xmlDoc.createProcessingInstruction('xml','version="1.0" encoding="UTF-8" standalone="yes"'); CurrNode := xmlDoc.appendChild(xmlProcessingInst); CurrNode := xmlDoc.createElement('soapenv:Envelope'); CurrNode := xmlDoc.appendChild(CurrNode); xmlMgt.AddAttribute(CurrNode,'xmlns:soapenv','http://schemas.xmlsoap.org/soap/envelope/'); xmlMgt.AddAttribute(CurrNode,'xmlns:mbs','http://www.microsoft.com/mbs/xml'); xmlMgt.AddElement(CurrNode,'soapenv:Header','','soapenv',NewChild); CurrNode:=NewChild; //One level deeper xmlMgt.AddElement(CurrNode,'soapenv:Body','','soapenv',NewChild); CurrNode:=NewChild; //one level deeper xmlMgt.AddElement(CurrNode,'mbs:enumeration','','mbs',NewChild); CurrNode:=NewChild; //one level deeper xmlMgt.AddElement(CurrNode,'mbs:table','Customers','mbs',NewChild); recCustomer.SETRANGE("No.", '10000','20000'); //Filter only few records IF recCustomer.FINDFIRST THEN BEGIN REPEAT vName :=recCustomer.Name; vNo :=recCustomer."No."; vContact:=recCustomer.Contact; recCustomer.CALCFIELDS("Balance (LCY)"); vBalance:= FORMAT(recCustomer."Balance (LCY)"); vSPcode :=recCustomer."Salesperson Code"; xmlMgt.AddElement(CurrNode,'mbs:Customer','','mbs',NewChild); CurrNode1:=NewChild; //One level deeper, but keep current level too xmlMgt.AddElement(CurrNode1,'mbs:CustomerAuthentication','','mbs',NewChild); CurrNode2:=NewChild; //One level deeper to sublevel xmlMgt.AddElement(CurrNode2,'mbs:No',vNo,'mbs',NewChild); xmlMgt.AddElement(CurrNode2,'mbs:Name',vName,'mbs',NewChild); xmlMgt.AddElement(CurrNode1,'mbs:CustomerData','','mbs',NewChild); CurrNode2:=NewChild; //One level deeper to sublevel xmlMgt.AddElement(CurrNode2,'mbs:Balance',vBalance,'mbs',NewChild); xmlMgt.AddElement(CurrNode2,'mbs:SalespersonCode',vSPcode,'mbs',NewChild); xmlMgt.AddElement(CurrNode2,'mbs:Contacts','','mbs',NewChild); CurrNode1:=NewChild;//One level deeper xmlMgt.AddElement(CurrNode1,'mbs:Contact',vContact,'mbs',NewChild); CLEAR(vName); CLEAR(vNo) ; CLEAR(vContact); CLEAR(vBalance); CLEAR(vSPcode); UNTIL recCustomer.NEXT=0; xmlDoc.save('D:xmlFile.xml'); CLEARALL; MESSAGE('xmlFile.xml is created'); END; END; } CODE { VAR xmlDoc@1000 : Automation "{F5078F18-C551-11D3-89B9-0000F81FE221} 6.0:{F6D90F11-9C73-11D3-B32E-00C04F990BB4}:'Microsoft XML, v6.0'.DOMDocument"; CurrNode@1003 : Automation "{F5078F18-C551-11D3-89B9-0000F81FE221} 6.0:{2933BF80-7B36-11D2-B20E-00C04F983E60}:'Microsoft XML, v6.0'.IXMLDOMNode"; CurrNode1@1005 : Automation "{F5078F18-C551-11D3-89B9-0000F81FE221} 6.0:{2933BF80-7B36-11D2-B20E-00C04F983E60}:'Microsoft XML, v6.0'.IXMLDOMNode"; CurrNode2@1013 : Automation "{F5078F18-C551-11D3-89B9-0000F81FE221} 6.0:{2933BF80-7B36-11D2-B20E-00C04F983E60}:'Microsoft XML, v6.0'.IXMLDOMNode"; NewChild@1004 : Automation "{F5078F18-C551-11D3-89B9-0000F81FE221} 6.0:{2933BF80-7B36-11D2-B20E-00C04F983E60}:'Microsoft XML, v6.0'.IXMLDOMNode"; xmlProcessingInst@1001 : Automation "{F5078F18-C551-11D3-89B9-0000F81FE221} 6.0:{2933BF89-7B36-11D2-B20E-00C04F983E60}:'Microsoft XML, v6.0'.IXMLDOMProcessingInstruction"; xmlMgt@1002 : Codeunit 6224; "---- Variables----"@1006 : Integer; recCustomer@1012 : Record 18; vName@1007 : Text[30]; vNo@1008 : Text[30]; vContact@1009 : Text[30]; vBalance@1010 : Text[30]; vSPcode@1011 : Text[30]; EVENT xmlDoc@1000: ![]() BEGIN END; EVENT xmlDoc@1000: ![]() BEGIN END; BEGIN END. } } --------------------------------------- And can be read by codeunit: OBJECT Codeunit 50050 xml read { OBJECT-PROPERTIES { Date=03/24/10; Time=12:25:26 PM; Modified=Yes; Version List=; } PROPERTIES { OnRun=BEGIN ffile.OPEN('D:XmlFile.xml'); //this must be your file name ffile.CREATEINSTREAM(strInStream); IF ISCLEAR(xmldomDoc) THEN CREATE(xmldomDoc); xmldomDoc.load(strInStream); xmlNodeList1 := xmldomDoc.getElementsByTagName('mbs:Customer'); ii:=xmlNodeList1.length(); FOR i:=0 TO xmlNodeList1.length()-1 DO BEGIN xmldomElem1:= xmlNodeList1.item(i); //mbs:Customer IF xmldomElem1.hasChildNodes() THEN BEGIN xmlNodeList2:= xmldomElem1.childNodes(); IF NOT ISCLEAR(xmlNodeList2) THEN xmldomElem2:= xmlNodeList2.item(0); //mbs:CustomerAuthentication IF NOT ISCLEAR(xmldomElem2) THEN IF xmldomElem2.hasChildNodes() THEN BEGIN xmlNodeList3:= xmldomElem2.childNodes(); IF NOT ISCLEAR(xmlNodeList3) THEN xmldomElem3:= xmldomElem2.firstChild();//mbs:No IF NOT ISCLEAR(xmldomElem3) THEN txtNo:=xmldomElem3.text(); xmldomElem3:=xmlNodeList3.item(1); //mbsName IF NOT ISCLEAR(xmldomElem3) THEN txtName:=xmldomElem3.text(); xmldomElem2:= xmlNodeList2.item(1); //mbs:CustomerData IF NOT ISCLEAR(xmldomElem2) THEN IF xmldomElem2.hasChildNodes() THEN BEGIN xmlNodeList3:= xmldomElem2.childNodes(); IF NOT ISCLEAR(xmlNodeList3) THEN xmldomElem3:= xmldomElem2.firstChild();//mbs:Balance IF NOT ISCLEAR(xmldomElem3) THEN txtBalance:=xmldomElem3.text(); xmldomElem3:=xmlNodeList3.item(1); //mbsSalesPersonCode IF NOT ISCLEAR(xmldomElem3) THEN txtSPcode:=xmldomElem3.text(); END; xmldomElem3:=xmlNodeList3.item(2); //mbs:Contacts IF NOT ISCLEAR(xmldomElem3) THEN txtContact:=xmldomElem3.text(); END; END; MESSAGE('This is record "%1"No "%2"Name "%3"Contact "%4"Balance "%5"Salesperson code "%6"of Total "%7"', FORMAT(i+1), txtNo, txtName, txtContact, txtBalance, txtSPcode, ii); END; ffile.CLOSE; CLEARALL; END; } CODE { VAR xmldomDoc@1000 : Automation "{F5078F18-C551-11D3-89B9-0000F81FE221} 6.0:{F6D90F11-9C73-11D3-B32E-00C04F990BB4}:'Microsoft XML, v6.0'.DOMDocument"; xmlNodeList1@1005 : Automation "{F5078F18-C551-11D3-89B9-0000F81FE221} 6.0:{2933BF82-7B36-11D2-B20E-00C04F983E60}:'Microsoft XML, v6.0'.IXMLDOMNodeList"; xmlNodeList2@1017 : Automation "{F5078F18-C551-11D3-89B9-0000F81FE221} 6.0:{2933BF82-7B36-11D2-B20E-00C04F983E60}:'Microsoft XML, v6.0'.IXMLDOMNodeList"; xmlNodeList3@1019 : Automation "{F5078F18-C551-11D3-89B9-0000F81FE221} 6.0:{2933BF82-7B36-11D2-B20E-00C04F983E60}:'Microsoft XML, v6.0'.IXMLDOMNodeList"; xmldomElem1@1007 : Automation "{F5078F18-C551-11D3-89B9-0000F81FE221} 6.0:{2933BF86-7B36-11D2-B20E-00C04F983E60}:'Microsoft XML, v6.0'.IXMLDOMElement"; xmldomElem2@1010 : Automation "{F5078F18-C551-11D3-89B9-0000F81FE221} 6.0:{2933BF86-7B36-11D2-B20E-00C04F983E60}:'Microsoft XML, v6.0'.IXMLDOMElement"; xmldomElem3@1011 : Automation "{F5078F18-C551-11D3-89B9-0000F81FE221} 6.0:{2933BF86-7B36-11D2-B20E-00C04F983E60}:'Microsoft XML, v6.0'.IXMLDOMElement"; txtNo@1001 : Text[30]; txtName@1002 : Text[30]; txtContact@1009 : Text[30]; txtBalance@1012 : Text[30]; txtSPcode@1013 : Text[30]; ffile@1003 : File; strInStream@1004 : InStream; i@1006 : Integer; ii@1018 : Integer; EVENT xmldomDoc@1000: ![]() BEGIN END; EVENT xmldomDoc@1000: ![]() BEGIN END; BEGIN END. } } That's all Special thanks to Rainer Kuhnlein Gedas Busniauskas (gediminb) Microsoft Customer Service and Support (CSS) EMEA Источник: http://feedproxy.google.com/~r/Micro...-xmlports.aspx
