emeadaxsupport: How to produce an item at time of sales order if there is residual balance of the finished goods
Источник: http://blogs.msdn.com/b/axsupport/ar...hed-goods.aspx
============== I had published a blog post earlier this month which covered the process of how to produce an item at time of sales order. In this post I will cover another scenario where there is residual stock of bagged item in the warehouse, and there is a requirement to produce the difference from a production order. This could be handled by Net requirement functionality from the sales order line, which will fire a planned production order by the difference. After firming the planned production order the system will create a production order to produce the quantity. The on-hand shows that the bagged item has physical inventory = 10 and the on order = 100 that is entered in a sales order line. ![]() Ensure that there is a coverage group on the item setup, with planned order type Production. ![]() Sales order with 100 ton. ![]() Then go to Product and Supply, and select Net requirement. ![]() Net requirement form ![]() In the lower pane select Update| Master scheduling ![]() Press OK ![]() A planned production order will be created, and you can see the line on the net requirement ![]() In order to Firm the planned production order, go to Production control| Common| Planned production order Ensure you filter on the same plan “DynPlan in my example” ![]() After Firming the planned production order, it will create a production order to be ended to produce the required quantity = 90. And you can see the reference to the sales order and planned order as well. ![]() Источник: http://blogs.msdn.com/b/axsupport/ar...hed-goods.aspx
