emeadaxsupport: Cloning a developer machine that has a TFS workspace may result in an error
Источник: http://blogs.msdn.com/b/axsupport/ar...-an-error.aspx
============== Setting up a developer box VM and cloning it for other developers is a great way to spin up machines quickly. However if you have already connected to a TFS workspace your machines may throw an error regarding the workspace when logging on a different user and opening the client for the first time. The TFS workspace files are cached on the client machine in the following directory. %userprofile%\appdata\local\microsoft\team foundation\3.0\cache The file you'll need to modify will be the VersonControl.config file. You can rename this file to VersionControl-old.config and re-launch the AX client, this will rebuild the config file with the appropriate workspace associated to the current user. Источник: http://blogs.msdn.com/b/axsupport/ar...-an-error.aspx
