Старый 24.09.2014, 13:11   #1
vasantharivali: Filter Second lookup based on First Value – Ax 2012 SSRS
Источник: http://vasantharivali.wordpress.com/...-ax-2012-ssrs/
Hi Folks,
I got one requirement to get invoices of a customer on the particular month range in SSRS Report Dialog. I have achieved that and want share. Here we go…..
Create a Contract Class with 4 parameter methods for Customer account, Month, Year, InvoiceId and follow the below code
1) Create a class for UI Builder
class SampleReportUIBuilder extends SrsReportDataContractUIBuilder{ DialogField dialogCustomer; DialogField dialogMonth; DialogField dialogYear; DialogField dialogInvoiceId; SampleDataContract dataContract;}2) override the build method
public void build(){ Dialog dialogLocal; dialogLocal = this.dialog(); dataContract = this.dataContractObject(); this.addDialogField(methodStr(SampleDataContract, parmCustAccount), dataContract); this.addDialogField(methodStr(SampleDataContract, parmMonth), dataContract ); this.addDialogField(methodStr(SampleDataContract, parmYear), dataContract ); this.addDialogField(methodStr(SampleDataContract, parmInvoiceId), dataContract );}3) override the initializeFields method
public void initializeFields(){ dataContract= this.dataContractObject();}4) override the getFromDialog Method
public void getFromDialog(){ comparisionDataContract = this.dataContractObject(); super();}5) add new method for CustomerAccount Lookup
public void lookupCustomerAcc(FormStringControl _control){ Query query = new Query(); QueryBuildDataSource qbdsCustomer; QueryBuildFieldList qbfsCustomerFieldList; SysTableLookup sysTableLookup; ; sysTableLookup = SysTableLookup::newParameters(tableNum(CustTable), _control); qbdsCustomer = query.addDataSource(tableNum(CustTable)); qbfsCustomerFieldList= qbdsCustomer .fields(); qbfsCustomerFieldList.dynamic(false); qbfsCustomerFieldList.clearFieldList(); qbfsCustomerFieldList.addField(fieldNum(CustTable, AccountNum)); qbfsCustomerFieldList.addField(fieldNum(CustTable, Party)); // Perform Lookup sysTableLookup.parmQuery(query); sysTableLookup.addLookupfield(fieldnum(CustTable, Id)); sysTableLookup.addLookupfield(fieldnum(CustTable, Party)); sysTableLookup.performFormLookup();}6) add Modified method for CustomerAcc
public boolean customerAccModified(FormStringControl _control){ dialogCustomer.value(_control.valueStr()); return true;}7) add new method for Year Lookup
//BP deviatedpublic void lookupYear(FormStringControl _control){ Query query = new Query(); YearBase maxYear; YearBase minYear; YearBase currentYear; // new own tmp table to hold year MyOwnYearTmp yearTmp; SysTableLookup sysTablelookup; sysTablelookup = SysTableLookup::newParameters(tableNum(KepYearTmp),_control); minYear = 1965; maxYear = year(systemDateGet()); yearTmp.recordLevelSecurity(true); for(currentYear = maxYear; currentYear >= minYear; currentYear--) { yearTmp.YearBase = currentYear; yearTmp.insert(); } sysTablelookup.addLookupfield(fieldNum(KepYearTmp,YearBase)); sysTableLookup.parmTmpBuffer(yearTmp); sysTableLookup.performFormLookup();}8) add new Modified method for Year
public boolean yearModified(FormStringControl _control){ dialogYear.value(_control.valueStr()); return true;}9) add InvoiceId lookup, this lookup will get data based on the selected customer, month and year
public void lookupInvoiceId(FormStringControl _control){ Query query = new Query(); QueryBuildDataSource qbdsCustInvoiceTable; QueryBuildRange qbrCustInvoiceTable; QueryBuildFieldList qbfsCustInvoiceTableFieldList; SysTableLookup sysTableLookup; TransDate invStDate, invEndDate; container conDates; ; sysTableLookup = SysTableLookup::newParameters(tableNum(CustInvoiceTable), _control); // my own class to get month startdate and enddate from dialog conDates= MyDateClass::getDateRange(dialogMonth.value() , dialogYear.value() , false, true); invStDate = conPeek(conDates, 1); invEndDate = conPeek(conDates, 2); // CustInvoiceTable DataSource qbdsCustInvoiceTable = query.addDataSource(tableNum(CustInvoiceTable)); qbdsCustInvoiceTable.addRange(fieldNum(CustInvoiceTable, InvoiceAccount)).value(queryValue(dialogCustomer.value())); qbdsCustInvoiceTable.addRange(fieldNum(CustInvoiceTable, InvoiceDate)).value(queryValue(invStDate)); qbdsCustInvoiceTable.addRange(fieldNum(CustInvoiceTable, InvoiceDate)).value(queryValue(invEndDate)); qbdsCustInvoiceTable.addRange(fieldNum(CustInvoiceTable, InvoiceStatus)).value(queryValue(InvoiceStatuses::Posted)); qbdsCustInvoiceTable.addRange(fieldNum(CustInvoiceTable, InvoiceType)).value(queryValue(InvoiceTypes::Invoice)); // CustInvoiceTable FieldList qbfsCustInvoiceTableFieldList = qbdsCustInvoiceTable.fields(); qbfsCustInvoiceTableFieldList.dynamic(false); qbfsCustInvoiceTableFieldList.clearFieldList(); qbfsCustInvoiceTableFieldList.addField(fieldNum(CustInvoiceTable, InvoiceAccount)); qbfsCustInvoiceTableFieldList.addField(fieldnum(CustInvoiceTable, InvoiceId)); qbfsCustInvoiceTableFieldList.addField(fieldNum(CustInvoiceTable, McsCmBilStartDate)); qbfsCustInvoiceTableFieldList.addField(fieldNum(CustInvoiceTable, McsCmBilEndDate)); qbfsCustInvoiceTableFieldList.addField(fieldNum(CustInvoiceTable, McsCmBilInvoiceStatus)); qbfsCustInvoiceTableFieldList.addField(fieldNum(CustInvoiceTable, McsCmBilInvoiceType)); // Perform Lookup sysTableLookup.parmQuery(query); sysTableLookup.addLookupfield(fieldnum(CustInvoiceTable, InvoiceId)); sysTableLookup.addLookupfield(fieldnum(CustInvoiceTable, McsConnectionId)); sysTableLookup.performFormLookup();}10) add new Modified method for InvoiceId
public boolean InvoiceIdModified(FormStringControl _control){ dialogInvoiceId.value(_control.valueStr()); return true;}11) override the PostBuild method
public void postBuild(){ super(); dialogCustomer = this.bindInfo().getDialogField(this.dataContractObject(),methodStr(SampleDataContract, parmCustomer)); if (dialogCustomer) { dialogCustomer.lookupButton(2); } // register override method for lookup dialogCustomer.registerOverrideMethod(methodStr(FormStringControl, lookup), methodStr(SampleReportUIBuilder , lookupCustomerAcc), this); // register override method for modified dialogCustomer.registerOverrideMethod(methodStr(FormStringControl, modified), methodStr(SampleReportUIBuilder , customerAccModified), this); // From binding info, get the dialog field for racecode attribute dialogMonth = this.bindInfo().getDialogField(this.dataContractObject(),methodStr(SampleDataContract, parmMonth)); // From binding info, get the dialog field for racecode attribute and add button dialogYear = this.bindInfo().getDialogField(this.dataContractObject(),methodStr(SampleDataContract,parmYear)); if (dialogYear) { dialogYear.lookupButton(2); } // register override method for lookup dialogYear.registerOverrideMethod(methodStr(FormStringControl, lookup), methodStr(SampleReportUIBuilder , lookupYear), this); // register override method for modified dialogYear.registerOverrideMethod(methodStr(FormStringControl, modified), methodStr(SampleReportUIBuilder , yearModified), this); dialogInvoiceId = this.bindInfo().getDialogField(this.dataContractObject(),methodStr(SampleDataContract, parmInvoiceId)); if (dialogInvoiceId) { dialogInvoiceId.lookupButton(2); } // register override method for lookup dialogInvoiceId.registerOverrideMethod(methodStr(FormStringControl, lookup), methodStr(SampleReportUIBuilder , lookupInvoiceId), this); // register override method for modified dialogInvoiceId.registerOverrideMethod(methodStr(FormStringControl, modified), methodStr(SampleReportUIBuilder , InvoiceIdModified), this);}11) Use the UI Builder class in Contract Calss as below
[ DataContractAttribute, SysOperationContractProcessingAttribute(classstr(SampleReportUIBuilder)), SysOperationGroupAttribute('Criteria', "@SYS13128", "1")]class SampleDataContract implements SysOperationInitializable, SysOperationValidatable{ CustomerAcc CustomerAcc; TransDate invoiceDate; MonthsOfYear invoiceMonth; Year invoiceYear; InvoiceId invoiceId;}Hope it will help……
// Vasanth Arivali
axStart: Call non AX reports on SSRS in AX 2012 Blog bot DAX Blogs 2 31.12.2013 16:43
kamalblogs: SSRS Tip: 5 Productivity tips for SSRS development in Dynamics AX 2012 Blog bot DAX Blogs 0 14.11.2013 11:11
kamalblogs: SSRS Tip: Using labels for dynamic texts in SSRS reports – Dynamics Ax 2012 Blog bot DAX Blogs 0 16.09.2013 12:11
ax-erp: Display Barcode in SSRS report [Dynamics AX 2012, X++] Blog bot DAX Blogs 0 19.07.2012 18:11
ax-erp: Duplicate SSRS reports [Dynamics AX 2012] Blog bot DAX Blogs 0 18.07.2012 19:11
Часовой пояс GMT +3, время: 05:32.
