Старый 27.01.2014, 19:12   #1
sashanazarov: Dynamics AX 2012: orig() method fails on derived tables
Источник: http://sashanazarov.blogspot.com/201...-fails-on.html
Just found a bug in the table inheritance feature (kernel 6.0.1108.5781).
If you have a base table A with field B, and a derived table C with field D, then C.orig().B will return a strange value (or nil, depending on the field type).
In order to get the correct value, you will need to downcast C to A, and then call A.orig().B.
This is the job that reproes the issue:
static void reproOrigBug(Args _args)
CompanyInfo companyInfo;
DirPartyTable dirPartyTable;
select firstOnly companyInfo;
info(companyInfo.orig().DataArea);
info(companyInfo.orig().Name);
dirPartyTable = companyInfo as DirPartyTable;
info(dirPartyTable.orig().Name);
And this is the output:
I will report the issue to MS Support.
ax2012, orig
kamalblogs: Error: SSRS/EP error when the return type in display method is incorrect – Dynamics AX 2012 Blog bot DAX Blogs 0 11.10.2013 12:11
ax-erp: Debug::assert() method calls in SYS layer triggering Dynamics AX 2012 debugger Blog bot DAX Blogs 0 10.12.2012 21:11
Sample Design Patterns: Book Give-away: 'Microsoft Dynamics AX 2012 Development Cookbook' Blog bot DAX Blogs 1 12.05.2012 16:55
rumicrosofterp: Dynamics AX на Convergence 2012 Blog bot Microsoft и системы Microsoft Dynamics 0 13.01.2012 11:11
mfp: Microsoft Dynamics AX 2012 is here! Blog bot DAX Blogs 10 04.08.2011 17:11
Часовой пояс GMT +3, время: 16:40.
