Добрый день всем.
Столкнулся с такой ошибкой при настройки ADFS. ADFS установлен на сервере где развернут MS SQL 2008R2. После установки ADFS и его настройки в журналах об ошибках появилась такая запись: Цитата:
Log Name: Application
Source: MSSQL$MICROSOFT##SSEE Date: 10/6/2013 9:30:29 AM Event ID: 28005 Task Category: (2) Level: Error Keywords: Classic User: N/A Computer: SQLCRM.mycompany.com Description: The description for Event ID 28005 from source MSSQL$MICROSOFT##SSEE cannot be found. Either the component that raises this event is not installed on your local computer or the installation is corrupted. You can install or repair the component on the local computer. If the event originated on another computer, the display information had to be saved with the event. The following information was included with the event: 15404 19 Could not obtain information about Windows NT group/user 'OFFICE\crmadmin', error code 0x5. The specified resource type cannot be found in the image file Цитата:
Log Name: Security
Source: Microsoft-Windows-Security-Auditing Date: 10/6/2013 9:42:47 AM Event ID: 4625 Task Category: Logon Level: Information Keywords: Audit Failure User: N/A Computer: SQLCRM.mycompany.com Description: An account failed to log on. Subject: Security ID: OFFICE\SQLSvc Account Name: SQLSvc Account Domain: OFFICE Logon ID: 0x103c4 Logon Type: 3 Account For Which Logon Failed: Security ID: NULL SID Account Name: Account Domain: Failure Information: Failure Reason: Unknown user name or bad password. Status: 0xc000006d Sub Status: 0xc0000064 Process Information: Caller Process ID: 0x5d0 Caller Process Name: C:\Windows\SYSMSI\SSEE\MSSQL.2005\MSSQL\Binn\sqlservr.exe Network Information: Workstation Name: SQLCRM Source Network Address: - Source Port: - Detailed Authentication Information: Logon Process: Authz Authentication Package: Kerberos Transited Services: - Package Name (NTLM only): - Key Length: 0 Кто сталкивался с такой проблемой может подскажите где копать? |
Да также пользователь OFFICE\SQLSvc добавлен в группу SQLServer2005MSSQLUser$COMPUTER$MICROSOFT##SSEE
Хелп!! Уже не знаю и куда копать... |
что ни у кого нет идей?
Тут написано, что логин OFFICE\SQLSvc не существует. С ним точно все в порядке, он есть в пользователях AD-домена, все дела?.. С настройками DNS на хосте SQLCRM тоже все в порядке, хост знает, к кому обращаться для логина в домен OFFICE?
Да пользователь есть в АД и подним крутиться Сиквел. В DNS тоже все хосты прописаны.
Так самое главное что не возможно зайти в СРМ по локальному пути, а вот по Интернет запросу все хорошо работает и ADFS в журналах не ругается. Но DNS еще раз проверю на всякий случай. |
Вот тут вот описывается похожая ситуация и предлагается пара вариантов решения.
Спасибо за помощь. Эту ссылку я читал и она не помогла.
Все оказалась проще был выключен сервер сертификатов |
| За это сообщение автора поблагодарили: a33ik (1). | |
