emeadaxsupport: Quick Tip: Testing another country's functionality
Источник: http://blogs.msdn.com/b/axsupport/ar...tionality.aspx
============== At times you might need to test a certain country's features in Microsoft Dynamics AX 2012- For example, you might want to test Belgian features, but the problem is you don't have a Belgian company To ensure that you can test Belgian or any other country's features, the principle is that you must have the country code defined in the AX legal entity's country code For example if you use our demodata and go to the company CEEI(Contoso Italy), normally it will not have any financial transactions as standard(a prerquisite to be able to define the primary legal entity) and you can therefore change the country code on the primary legal entity from 'ITA" to 'BEL'. After this exit AX, and reenter and you can see you will have Belgian(or any other) country features enabled for this legal entity ![]() Источник: http://blogs.msdn.com/b/axsupport/ar...tionality.aspx
