Старый 16.08.2013, 11:53   #1
zipo is offline
zipo
AX2012R2 AOS падает при старте Reporting Services
Такая штука, если настроить нормально бизнес коннектор на АОС и стартовать сервис
SQL Server Reporting Services
То через время (до 3 минут) падает АОС с такой вот ошибкой:
The description for Event ID 180 from source Microsoft Dynamics AX cannot be found. Either the component that raises this event is not installed on your local computer or the installation is corrupted. You can install or repair the component on the local computer.
If the event originated on another computer, the display information had to be saved with the event.
The following information was included with the event:
Microsoft Dynamics AX Business Connector Session 3.
Ктони будь знает как можно поправить?
Rahul Sharma: Dynamics AX 2012 & SQL Reporting Services 2012 Reporting Extensions Error Blog bot DAX Blogs 0 23.10.2012 04:23
emeadaxsupport: Microsoft Dynamics AX 2012 Reporting Services – Scale-out deployments Blog bot DAX Blogs 0 28.11.2011 00:14
emeadaxsupport: Reporting Extensions Installation Fails to install on SQL 2008 Reporting services after applying 959494 and 957312 Blog bot DAX Blogs 1 23.06.2011 14:27
gatesasbait: Installing Reporting Services, Analysis Services and Enterprise Portal for AX 2009 Blog bot DAX Blogs 0 03.07.2008 02:05
Часовой пояс GMT +3, время: 14:42.
