Старый 09.10.2012, 17:11   #1
emeadaxsupport: The Report Server Configuration ID could not be found in the SRSServers table
Источник: http://blogs.msdn.com/b/axsupport/ar...ers-table.aspx
When attempting to run a report in Microsoft Dynamics AX 2012 you might run into an error that says '
'The default Report Server Configuration ID could not be found in the SRSServers table.'
If you are faced with this error, try to go to System administration> Setup> Business intelligence> Reporting services> Report servers> change server name to (here DAX2012) as well as ensure that your Report Manager URL, Web service URL and Application Object Servier information reflect this server as highlighted on the screenshot:
After this go to AOT> SSRS reports> Reports> find your report> right click> Deploy element and see then if you are not able to sucesscully launch the report
emeadaxsupport: Opening a Report on AX 2012 raises infolog error: The default Report Server Configuration ID could not be found in the SRSServers table. Blog bot DAX Blogs 0 02.12.2011 00:13
emeadaxsupport: Error message “The value ‘xxx’ is not found in the map” when opening Workflow configuration Blog bot DAX Blogs 0 10.02.2010 00:07
emeadaxsupport: Error when deploying AX Report to SQL Reporting Server - Client found response type of 'text/html;charset=utf8;' but expected 'text/html' Blog bot DAX Blogs 0 12.01.2010 04:44
Часовой пояс GMT +3, время: 05:35.
