Возьми свет!!!
EP: XMLDocument::createBlank вызывает ошибку
Доброго времени суток
вот такая ошибка валится когда внутри weblet вызывается метод XMLDocument::createBlank() X++: runWebletItem Microsoft Dynamics.
"Microsoft.Dynamics.Xml, Version=4.0.0.0, Culture=neutral, PublicKeyToken=31bf3856ad364e35" . . ( HRESULT: 0x80131418)
System.IO.FileLoadException
DotNet.XmlDocument.New(XmlNameTable* )
xXmlDocument.kcNewBlank(xXmlDocument* , interpret* )
interpret.doInternalEval(interpret* , Char* inputStr, cqlClass* cinfo, xKernelClass* kernelObject, UInt16 chndl)
interpret.evalFunc(interpret* , Char* src, Byte isKernelClass, Byte runFlags, UInt16 chdl, Byte mode, Byte origmode, cqlClass* cinfo, xRPNList* rl)
interpret.xal_eval_func(interpret* , Byte mode, UInt16 chdl, xRPNList* rl, Char* src)
interpret.xal_eval_id(interpret* )
interpret.evalloop(interpret* )
interpret.evalLoop(interpret* )
interpret.eval(interpret* )
interpret.CQLEvalProc(interpret* , Byte* rpncs, Int32 noelem, Byte varallocated, Int32 mode, UInt16* fctoff, UInt16 cur_class, Char* modulename, xRPNList* rl)
interpret.doEval(interpret* , Char* inputStr, Byte mode, UInt16* fctoff, cqlClass* cinfo, Byte runFlags, xRPNList* rl)
cqlClass._call(cqlClass* , Char* name, interpret* ip)
AxCore_Call(UInt32 objectHandle, Char* pszMethodName, tagVARIANT* args, Int32 argsCount, tagVARIANT* result)
Microsoft.Dynamics.BusinessConnectorNet.AxaptaObject.Call(String methodName, Object[] paramList)
Microsoft.Dynamics.WebParts.SessionItem.AxaptaObjectImpl.Microsoft.Dynamics.WebParts.IAxaptaObject.Call(String methodname, Object[] paramlist)
System.Security.Policy.PolicyException
System.Security.SecurityManager.ResolvePolicy(Evidence evidence, PermissionSet reqdPset, PermissionSet optPset, PermissionSet denyPset, PermissionSet& denied, Boolean checkExecutionPermission)
System.Security.SecurityManager.ResolvePolicy(Evidence evidence, PermissionSet reqdPset, PermissionSet optPset, PermissionSet denyPset, PermissionSet& denied, Int32& securitySpecialFlags, Boolean checkExecutionPermission)
, "http://go.microsoft.com/fwlink/events.asp".X++: public void run(Args args) { IISRequest req; ComVariant l,b; XMLTextReader xmlReader; XMLDocument xmlDoc; str xml; BinData binData; XMLParseError error; AscIIIo ascIIo; ; setLogInfolog(NoYes::Yes); req = new IISRequest(); l = new COMVariant(); l.long(req.totalBytes()); b = req.binaryRead(l); binData = new BinData(); binData.setVariant(b); xml = binData.getStrData(); xmlDoc = XMLDocument::newBlank(); ascIIo = new AscIIIO(strfmt("C:\\%1a.xml",timenow()),"W"); ascIIo.writeRaw(xml); }
Axapta 3.0 sp 5 Oracle ![]() Я могу взорвать вам мозг!!! |
Возьми свет!!!
http://support.microsoft.com/kb/943836
а вот решение
