palleagermark: Using Team Foundation Service with AX 2012
Источник: http://palleagermark.blogspot.com/20...e-with-ax.html
============== Microsoft is working on enabling Team Foundation Server as a cloud based service. You can try it out for free for the time being and you can even use it with AX 2012. You can up for the service here: http://tfspreview.com/ In order to connect to the site from AX (and Visual Studio) you need to install the following:
The address for the Team Foundation Server to use for setup in AX is: https://yoursitename.tfspreview.com:...aultcollection The rest of the setup in AX is the same as usual. These sources made it possible for me to figure this out - thanks: TFS connection string using TFS preview First Experience of tfspreview, connect to tfspreview using VS 2010 I haven't tried to use this from AX 2009, but I'd imagine that would work as well. Источник: http://palleagermark.blogspot.com/20...e-with-ax.html
