sashanazarov: The X++ debugger does not open...
Источник: http://sashanazarov.blogspot.com/201...-not-open.html
============== ... although you turned off "Execute business operations in CIL" in the "Tools > Options". Then there is probably a runAs(...) method somewhere down the call stack. You can find such a runAs-call by setting a breakpoint in Visual Studio, attaching to the process and running your logic again. After the runAs-call is found, you can simply go replace it with a direct static method call. For example: After this change, the X++ debugger will stop where needed. Remember - this change is only for debugging purpose. You should not do that in the production code. Источник: http://sashanazarov.blogspot.com/201...-not-open.html
