Gareth Tucker: CRM 2011 Upgrade–Outlook Client Considerations
Источник: http://gtcrm.wordpress.com/2011/04/0...onsiderations/
============== Here’s an excellent post that spells out everything you need to know: http://blogs.msdn.com/b/crminthefiel...2011-tips.aspx Bottom line is: get your CRM 4 clients onto at least rollup 10 and then you are ok to upgrade the server to CRM 2011. Your CRM 4 clients will continue to function – even with offline data – and you can upgrade the clients at your leisure (with some constraints around going offline). ![]() Источник: http://gtcrm.wordpress.com/2011/04/0...onsiderations/
