Старый 01.09.2009, 07:11   #1
lcash: Lean Manufacturing demo scripts
Источник: http://blogs.msdn.com/lcash/archive/...o-scripts.aspx
I had a question from a partner looking for demo scripts for Lean Manufacturing. You can find ones that the dev team prepared for use with the data set that on Refresh 2 of the demo VM. You can find the scripts here
https://mbs.microsoft.com/partnersou...lse&stext=Lean
If you are looking for instructions on using the Lean disk for the demo VM’s this note will help you out.
http://blogs.msdn.com/lcash/pages/dy...tup-notes.aspx
Cheers
Lachlan
Original post at http://blogs.msdn.com/lcash
Arijit Basu: Managing Lean Manufacturing using Microsoft Dynamics AX 2009 Blog bot DAX Blogs 0 31.07.2009 00:06
lcash: Microsoft Demo Showcase Suite Release at WPC2009 Blog bot DAX Blogs 0 30.07.2009 08:06
lcash: Using document handling to add image in Demo VM Blog bot DAX Blogs 0 21.07.2009 10:05
Dynamics AX: Pre-release of Lean Manufacturing for Microsoft Dynamics AX Blog bot DAX Blogs 0 03.04.2009 21:06
Часовой пояс GMT +3, время: 18:35.
