Старый 20.04.2023, 23:17   #1
X++ to run XIRR
Источник: http://alexvoy.blogspot.com/2023/04/x-to-run-xirr.html
I created a small X++ wrapper to call XIRR function from the C# project provided by https://github.com/klearlending/XIRR (Thank you!)
You can test XIRR function in Excel, btw.
using tmxExcelFinance;/// /// Implements various financial functions/// public final class mgcFinanceFunction{ /// /// Calculates XIRR value /// /// List of containers kind [cashflow amount, its date] /// how many decimals to calculate /// Maximum rate /// XIRR value public static real calculateXIRR(List _cashFlows, int _decimals, real _maxRate = 1000000) { var cashFlows = new System.Collections.Generic.List(); System.Collections.IEnumerable cashFlowsI; ListEnumerator leC = _cashFlows.getEnumerator(); System.Double dbl; System.DateTime dt; while(leC.moveNext()) { [dbl, dt] = leC.current(); cashFlows.Add(new CashFlowDates(dbl, dt)); } // convert to iterable cashFlowsI = cashFlows; return XIRR::Calc(cashFlowsI, _decimals, _maxRate); }}
This is how we can call the wrapper
public static void calculateXIRRFromInvestmentDetailsLineTmp(RefRecId _projTableRecId, mgcInvestmentDetailsLineTmp _mgcInvestmentDetailsLineTmp) { List listCashFlowsDates = new List(Types::Container); mgcInvestmentDetailsLineTmp mgcInvestmentDetailsLineTmpLocal; mgcInvestmentDetailsLineTmpLocal.linkPhysicalTableInstance(_mgcInvestmentDetailsLineTmp); while select mgcInvestmentDetailsLineTmpLocal { listCashFlowsDates.addEnd([mgcInvestmentDetailsLineTmpLocal.TransactionCurrencyAmount, DateTimeUtil::newDateTime(mgcInvestmentDetailsLineTmpLocal.LineDate, 0)]); } mgcProjXIRRTable.XIRRValue = mgcFinanceFunction::calculateXIRR(listCashFlowsDates, 4);...
Or
cashFlows1 = new List (Types::Container); cashFlows1.addEnd([-10000,str2Date("01/01/2008", 123)]); cashFlows1.addEnd([2750, str2Date("01/03/2008", 123)]); cashFlows1.addEnd([4250, str2Date("30/10/2008", 123)]); cashFlows1.addEnd([3250, str2Date("15/02/2009", 123)]); cashFlows1.addEnd([2750, str2Date("01/04/2009", 123)]);res = mgcFinanceFunction::calculateXIRR(cashFlows1, 10);
Notes about the solution creation.
D365FO project must be v4.6
Last remark. I tried to implemented the same algorithm in X++, but I bumped into two limitations.
First, there is a limit for recursion depth - 400 levels; we can flatten it, though.
Second, real loses required decimals and ends up with division by zero.
daxmusings: Design-Compile-Run Part3: Design, Compile, Run in AX7 Blog bot DAX Blogs 0 05.05.2016 08:11
daxmusings: Design-Compile-Run Part2: Design, Compile, Run in AX 2012 Blog bot DAX Blogs 0 04.05.2016 13:11
emeadaxsupport: IDMF - How to troubleshoot job status issues like Last run result = Error Blog bot DAX Blogs 10 04.11.2015 16:09
Van Vugt: CODEUNIT.RUN - Conclusion Blog bot Dynamics CRM: Blogs 0 09.12.2012 17:29
Ошибка бизнес-процесса Tarasov E Dynamics CRM: Разработка 9 18.02.2010 14:02
Часовой пояс GMT +3, время: 21:42.
