Старый 22.07.2019, 14:11   #1
crmtipoftheday: Tip #1283: Too many birthdays
Источник: https://crmtipoftheday.com/1283/too-many-birthdays/
Outlook has a fantastic feature that reminds you when your contacts have a birthday. You will see a repeating appointment on your calendar that notifies you about their birthday.
The problem with this feature is if you frequently connect to different Dynamics 365 environments, such as a trial environment, and you want to demonstrate Outlook/Exchange synchronization.
If there are contacts in the environment with a value in the birthday field and you synchronize Outlook contacts with that environment, you may start seeing birthday reminders for people who don’t exist–the sample data in your demo environments.
If you have phantom birthdays appearing on your calendar, here is a sure-fire way to clean it up:
  • Navigate to your Outlook calendar
  • Search for “birthday”
  • Delete the results (except for your mom)
crmtipoftheday: Tip #1103: Chart styling cheat sheet Blog bot Dynamics CRM: Blogs 0 08.04.2018 03:03
crmtipoftheday: Tip #1101: Add a scale break to charts Blog bot Dynamics CRM: Blogs 0 07.04.2018 04:03
crmtipoftheday: Tip #1095: Add percentage labels to pie charts Blog bot Dynamics CRM: Blogs 0 02.04.2018 04:16
crmtipoftheday: Tip #1060: Quickly create vector/SVG images for Dynamics 365 Blog bot Dynamics CRM: Blogs 0 24.01.2018 22:11
Часовой пояс GMT +3, время: 07:19.
