dynamicsnavax: Business Events and Date format in Flow
Источник: http://dynamicsnavax.blogspot.com/20...t-in-flow.html
============== Business Events formats Dates in the Microsoft JSON format, e.g. "EventTime": "/Date(1560839609000)/" I wish it was in ISO8601 standard e.g. "2019-06-18T05:40Z". Below is what I did using Flow. First get the integer part of the string by using the replace function. Function: int(replace(replace('/Date(1560839609000)/','/Date(',''), ')/', '')) Output: 1560839609000 To format into date. Function: addseconds('1970-1-1', Div(1560839609000,1000) , 'yyyy-MM-dd') Output: 2019-06-18 To format into datetime. Function: addseconds('1970-1-1', Div(1560839609000,1000) , 'yyyy-MM-dd hh:mm:ss') Output: 2019-06-18 06:33:29 Using an online converter I am able to validate my output. https://www.epochconverter.com/ After that, you can use the Date Time string to or formatDateTime function. For the developers out there. Newtonsoft is great for working with dates and supports both formats. Have a look at this link for a bit more info. https://www.newtonsoft.com/json/help...atesInJSON.htm If you have a better way of handling dates. Please let me know. Источник: http://dynamicsnavax.blogspot.com/20...t-in-flow.html
