Старый 27.12.2018, 15:11   #1
sinedax: Trace Parser doesn't work - Dynamics 365 for Finance & Operations
Источник: http://sinedax.blogspot.com/2018/12/...amics-365.html
Hi All and Happy Christmas!!
Below, I'll share an issue that wasted my time during an Performance investigation.
I have to say also thanks to Microsoft Technical support for helping me.
Some ETL files opened with Trace Parser on a onebox VM, didn't show up any methods and any queries. Something like that:
Cause: The ETW Providers “Microsoft-AX-XPPExecutionTraces” and “Microsoft-Dynamics-AX-ExecutionTraces” aren't installed in the VM!
Microsoft-Dynamics-AX-XppExecutionTraces : Used to capture X++ methods events.
Microsoft-Dynamics-AX-ExecutionTraces : Used to capture SQL events.
Resolution : In that case you can install the missing providers with the following steps:
Find the location of the manifest files. If you are using a onebox VM they are in C:\AOSService\webroot\Monitoring
Open a Powershell as Administrator and run the following commands to install the 2 missing event providers:
$resourcefiledir = "C:\AOSService\webroot"
$inputmanfile = "C:\AOSService\webroot\Monitoring\DynamicsAXExecutionTraces.man"
$outputmanfile = "C:\AOSService\webroot\Monitoring\DynamicsAXExecutionTraces_copy.man"
$temp = Get-Content $inputmanfile
$temp = $temp -replace "%APPROOT%",$resourcefiledir
$temp | out-file $outputmanfile
wevtutil im $outputmanfile
$inputmanfile = "C:\AOSService\webroot\Monitoring\DynamicsAXXppExecutionTraces.man"
$outputmanfile = "C:\AOSService\webroot\Monitoring\DynamicsAXXppExecutionTraces_copy.man"
Close and open Trace Parser again and verify the providers are visible in the list.
Another way is to:
Copy c:\Monitoring folder from a 7.2 working VM
Run MonitoringInstall.cmd from Command Prompt running as Administrator in this folder
I guess with the new VM version this issue is gone!
Enjoy!
powerobjects: How to Integrate Power BI with Dynamics 365 for Finance and Operations Blog bot Dynamics CRM: Blogs 0 26.06.2018 01:23
sinedax: Fast Deployment - Dynamics 365 for Finance & Operations LBD Blog bot DAX Blogs 0 07.05.2018 00:15
sinedax: Violation of PRIMARY KEY constraint 'I_65518FIELD' - Dynamics 365 for Finance & Operations LBD Blog bot DAX Blogs 0 06.05.2018 18:13
stoneridgesoftware: Making Dynamics 365 Workspaces Work for You with Count Tiles and Tabbed Lists Blog bot DAX Blogs 0 11.04.2017 20:13
Часовой пояс GMT +3, время: 19:21.
