crmtipoftheday: Tip #1179: Add a dash of dash to your autonumbering
Источник: https://crmtipoftheday.com/1179/add-...autonumbering/
============== &tl;dr Jonas “The Shuffler” Rapp reports: when modifying autonumbering for built-in entities like case, always include a dash in the pattern to stop Dynamics 365 from self-combusting. Long story One of the awesome users of the Auto Number Manager for XrmToolBox managed to break the system settings for Auto Numbers in Dynamics 365, so he called me up to see if I could find the problem. ![]() The Auto Number Format of the Case Number (ticketnumber) attribute on the Case (incident) entity had been changed from the default value: CAS-{SEQNUM:5}-{RANDSTRING:6} To a custom format: CASE{SEQNUM:7} And now it was no longer possible to open the Auto-Numbering dialog in Dynamics 365. I see four potential problems here:
![]() So make sure you keep a DASH between your prefix and number when you are changing Auto Number Format for out of the box number attributes! Happy numbering! Источник: https://crmtipoftheday.com/1179/add-...autonumbering/
