Старый 22.03.2018, 16:11   #1
axtoday: Setup an external catalogue for PunchOut eProcurement
Источник: http://axtoday.blogspot.com/2018/03/...-punchout.html
D365O has a functionality to do PunchOut eProcurement. The main idea is not having to maintain the vendor item numbers in your system as well as always having the latest information on the vendor items.
Read more in here https://docs.microsoft.com/en-us/dyn...g-for-punchout
The steps needed to set this up:
  1. Open Procurement and sourcing > Catalogues > External catalogues
  2. Create a new entry, map it against a vendor, and select one or more the procurement category that will be used. If you only have one procurement category, then all items returned from the vendor’s website will be mapped to that category, otherwise you will have to map the items manually.
  3. The most important setting will be on the message format section, where you will need to configure it so that D365O knows which URL to open, what kind of information that needs to be passed to the vendor’s website. You should contact your vendor (which supports PunchOut eProcurement) to get the information.
  4. Some dynamic information can be configured in the Extrinsics section. Currently the possible dynamic value options are user email, User name, and random value.
  5. You can then click “Validate settings” to make sure that you can open the vendor’s website without any error.
  6. After that, you can then activate the catalogue.
Once you’ve done all that, in the purchase requisition form, you can click the “External catalogues” button on the line section, which will open a dialog where you can choose which vendor’s website that you want to open (based on the configuration that you’ve done on the external catalogues form).
When you click the button, you will get a prompt that says that you will now be redirected to an external site, and after you click OK, you should see the vendor’s website.
You can then place items into the shopping basket, and when you have completed the check out, it will take you back to D365O which gives you the chance to review the order. You can remove lines that you don’t need, or you can choose a different procurement category if needed.
When you click the Add to requisition button at the bottom of the page, it will then transfer the lines into the purchase requisition.
Few important notes:
  • The unit of measurements from the vendor’s website need to exist in D365O, otherwise the lines will be ignored in the validate shopping cart form.
  • The vendor’s website must support TLS v1.2 as D365O environments in tier 2 or higher enforce it.
  • There is a bug (in application 7.2 and 7.3) where it is expecting an element called “SupplierPartAuxiliaryId” in the XML response from the vendor’s website, which the value from that element is not being used in D365O. The bug will only become an issue if the XML response from the vendor’s website do not have that element.
    KB4094740 can be installed to resolve the issue.
alexef: Sample Extension v2.0 — Dynamics NAV / AL extension / SaaS — ALF Export Setup Tabs to Excel Blog bot NAV: Blogs 3 05.10.2018 23:13
organicax: External catalog setup using cXML in D365 – Part 1 Blog bot DAX Blogs 0 10.08.2017 20:11
mbsturk: AppFabric, PSModulePath and Error Code 1603 Blog bot DAX Blogs 0 21.01.2013 21:11
Muhammad Ali Khan: Relating/Connecting MS CRM 4.0 Data With Custom External Content Type Data In SharePoint 2010 Blog bot Dynamics CRM: Blogs 0 04.02.2010 13:05
Jim Wang: CRM 4.0 External Connector License Blog bot Dynamics CRM: Blogs 0 11.02.2009 06:05
Часовой пояс GMT +3, время: 04:24.
