dynamicsaxhints: The power of firstOnly keyword
Источник: http://dynamicsaxhints.blogspot.com/...y-keyword.html
============== Sometimes only one record from a table is required, but firstOnly keyword is not used by a developer. For example: select AccountNum from custTable where custTable.CustGroup == '10'; if (custTable.AccountNum) { ... } What difference does it make? Problem description Compare select statements with and without firstOnly keyword. Hints Use SQL Server Profiler for analysis and trace RPC:Starting and RPC:Completed events: Solution The first test is the select statement with firstOnly keyword. RPC:Starting event is below: declare @p1 int set @p1=NULL declare @p2 int set @p2=0 declare @p5 int set @p5=28688 declare @p6 int set @p6=8193 declare @p7 int set @p7=2 exec sp_cursorprepexec @p1 output,@p2 output,N'@P1 bigint,@P2 nvarchar(5),@P3 nvarchar(11)',N'SELECT TOP 1 T1.ACCOUNTNUM,T1.RECID FROM CUSTTABLE T1 WHERE (((PARTITION=@P1) AND (DATAAREAID=@P2)) AND (CUSTGROUP=@P3))',@p5 output,@p6 output,@p7 output,5637144576,N'usmf',N'10' select @p1, @p2, @p5, @p6, @p7 The most interesting parameter here is @p7. It is the number of fetch buffer rows (more details are on msdn and blog posts). I do not know why 2 records are requested, but based on RPC:Completed event only 1 record is fetched: declare @p1 int set @p1=1073741872 declare @p2 int set @p2=180150427 declare @p5 int set @p5=16 declare @p6 int set @p6=1 declare @p7 int set @p7=1 exec sp_cursorprepexec @p1 output,@p2 output,N'@P1 bigint,@P2 nvarchar(5),@P3 nvarchar(11)',N'SELECT TOP 1 T1.ACCOUNTNUM,T1.RECID FROM CUSTTABLE T1 WHERE (((PARTITION=@P1) AND (DATAAREAID=@P2)) AND (CUSTGROUP=@P3))',@p5 output,@p6 output,@p7 output,5637144576,N'usmf',N'10' select @p1, @p2, @p5, @p6, @p7 The second test is the select statement without firstOnly keyword. RPC:Starting event is below: declare @p1 int set @p1=NULL declare @p2 int set @p2=0 declare @p5 int set @p5=28688 declare @p6 int set @p6=8193 declare @p7 int set @p7=10 exec sp_cursorprepexec @p1 output,@p2 output,N'@P1 bigint,@P2 nvarchar(5),@P3 nvarchar(11)',N'SELECT T1.ACCOUNTNUM,T1.RECID FROM CUSTTABLE T1 WHERE (((PARTITION=@P1) AND (DATAAREAID=@P2)) AND (CUSTGROUP=@P3))',@p5 output,@p6 output,@p7 output,5637144576,N'usmf',N'10' select @p1, @p2, @p5, @p6, @p7 RPC:Completed event: declare @p1 int set @p1=1073741868 declare @p2 int set @p2=180150467 declare @p5 int set @p5=16 declare @p6 int set @p6=1 declare @p7 int set @p7=10 exec sp_cursorprepexec @p1 output,@p2 output,N'@P1 bigint,@P2 nvarchar(5),@P3 nvarchar(11)',N'SELECT T1.ACCOUNTNUM,T1.RECID FROM CUSTTABLE T1 WHERE (((PARTITION=@P1) AND (DATAAREAID=@P2)) AND (CUSTGROUP=@P3))',@p5 output,@p6 output,@p7 output,5637144576,N'usmf',N'10' select @p1, @p2, @p5, @p6, @p7 It means that 10 records are fetched into buffer instead of 1 record required in X++ code. Why? It is specifics of a cursor statement. In X++ it is possible to use next statement after a select statement to fetch an additional record. Why 10? The default is 20 rows, but the actual value is calculated as Maximum Buffer Size / Row Length. Conclusion It seems to be not a big deal, but small problems usually escalate. Using firstOnly keyword definitely improves performance. Источник: http://dynamicsaxhints.blogspot.com/...y-keyword.html
