organicax: WMS Mobile device menu – License plate build
Источник: https://organicax.com/2016/08/31/wms...e-plate-build/
============== If you need to move multiple license plates around the warehouse you can have a look at using the parent license plate functionality. You can work with this by building a parent license plate and adding other license plates under the parent through the license plate build menu item. Here is a quick overview. AX2012 R3 CU10. Cheers Lachlan Filed under: Warehouse management Источник: https://organicax.com/2016/08/31/wms...e-plate-build/
