There is a day when every Navision consultant whished Navision supported Unicode. During an implementation I tough if it is so difficult by Microsoft to implement Unicode in Navision?
The concept of dataports it’s a simple an easy way to integrate Navision with external applications. Now try to incorporate text files with a custom made Korean ERP, isn’t an easy task. How I wished for Unicode. In a way to solve 5% the missing of Unicode in Navision, I created two tiny utilities. Download can be made from http://dynamicsuser.net/files/folders/nav_...entry84404.aspx The first is a GUI application to convert text files between two code pages. This application it’s far from a master piece, but solved some issues to me. Most of the used of this utility can be replaced by Notepad. The second utility is a COM object with the same purpose. It is normally executed before running a dataport. This object accepts 4 parameters: - Code page of source file - Source file - Code page of destination file - Destination file None of these utilities solves the problem of having and displaying in same company chartsets from 2 different code pages. I hope that in a near future that problem it’s solved. Probably Unicode is implemented in 6.0 Подробнее... http://dynamicsusers.org/blogs/nunomaia/ar...nd-unicode.aspx
