Старый 23.09.2013, 23:11   #1
mfp: X++ Debugging Tips and Tricks
Источник: http://blogs.msdn.com/b/mfp/archive/...ks-part-1.aspx
I hate debugging - I would much rather write code or watch tests execute! Debugging is a waste of time, and often follows an unpredictable path.
Any developer knows the situation: A bug is discovered, and the cause must be found. Most developers have these war stories on how they fought with a bug. The battle swung back and forth. Theories were tested and discarded, instrumentation was built, log files were examined, Murphy visited and, coffee was spilled. When the stories are told, they typically have a happy ending, so eventually the Eureka-moment occurred and the cause was found. And a debugging lesson was learned.
One of my toughest debugging session spanned almost 2 weeks. My code was complete and ready for check-in. I had worked on it for about 2 months in a private branch. Before reverse integrating into the main branch I ran all unit tests. A successful run takes about 12 hours. In my case the execution crashed after about 10 hours. I tried to run the single test case that crashed in isolation. It passed. I tried again with the full automation. It still crashed. I then tried disabling the crashing test, just to realize 10 hours later, that now a different test crashed. I then tried running with a debug version of AX32, so I could debug the crash. But the debug build is much slower, so it would take ages before the crash happened. So I needed to isolate the crash in a simpler repro. I tried changing the order of tests, and with every change I made the crash moved somewhere else. I then began trawling the system logs for information about the crash. This lead me to think about memory – perhaps something was leaking memory. I instrumented the test automation, so it would dump the current memory footprint every 10 seconds to a log file. And yes – memory consumption climbed until the crash occurred. But hey; I’m just writing X++ code – what can I possibly do that causes memory to leak? Driving home one day I got the idea that perhaps it was not my code, but the X++ runtime. After all; I was using some of the not-yet-released-at-this-point X++ features pretty heavily (attributes and events). So I wrote a small job, that exercised these areas heavily, and I saw memory climbing slowly but steadily until the crash. Now with a simple repro in hand, it was not hard to solve the issue – but I did require help from my friends in the X++ team. Two weeks had passed before I was ready to submit, my code was exactly the same, and now all test passed.
This X++ debugging series of posts is dedicated to share X++ debugging tips and tricks. Having a toolbox full of different ways to attack bugs is required to be a productive developer. I’m going to share some of my tricks. If you have tricks of your own, please write a comment, and I will include them in the series. The ultimate goal is that we all efficiently find and solve X++ bugs.
Trick #1 – Breakpoint in Info.add()
Trick #2 – To be announced
Trick #3 – To be announced
Trick #4 – To be announced
Trick #5 – To be announced
Старый 24.09.2013, 12:48   #2
kashperuk is offline
kashperuk
Аватар для kashperuk
4,361 / 2084 (78) +++++++++
А мне нравится дебажить, особенно когда уже приближаешься к разгадке - кровь приливает, вены пульсируют, запах крови витает в комнате, лепота
Старый 24.09.2013, 13:01   #3
fed is offline
fed
Аватар для fed
2,914 / 5737 (197) ++++++++++
Чуствуется это запах крови разработчиков, а не тестеров
Вообще - странно что MFP, после перехода в команду Логистики и Производства пишет посты про среду разработки и отладки...
sumitax: EP Debugging Tips and Tricks –Part III Blog bot DAX Blogs 0 13.10.2010 14:05
sumitax: EP Debugging Tips and Tricks –Part II Blog bot DAX Blogs 0 30.09.2010 09:05
sumitax: EP Debugging Tips and Tricks –Part I Blog bot DAX Blogs 0 13.08.2010 21:06
Solutions Monkey: Convergence session: Enterprise Portal Deployment Tips and tricks Blog bot DAX Blogs 0 26.03.2009 08:05
Solutions Monkey: Microsoft Dynamics AX 2009 Enterprise Portal / Role Centers - Deployment Tips-n-Tricks – 3 Blog bot DAX Blogs 0 27.10.2008 08:05
Часовой пояс GMT +3, время: 06:22.
