ax-erp: ‘Not Like’ in Dynamics AX
Источник: http://microsoft-dynamics-ax-erp.blo...namics-ax.html
============== In X++, we can use Like ‘*someIdentifier’ to implement the Like keyword. e.g. select firstonly purchTable where purchTable.purchId like ‘00007*‘; However if you want to use ‘Not Like’ in X++ SQL statement, you have three options: The first option, using ‘!’ as ‘not’, e.g. select firstonly purchTable where !(purchTable.purchId like ‘00007*‘); The second option, using notExists join e.g. PurchTable purchTable, refPurchTable; ; select firstonly purchTable notExists join refPurchTable where purchTable.purchId == ‘00007*‘; Please make sure that you do put purchTable.purchId in condition statement, otherwise the SQL statement will retrieve an empty result set. The last option, using Query e.g. Query query = new Query(); QueryRun queryRun; ; query.addDataSource(tableNum(PurchTable)).addRange(fieldNum(PurchTable, PurchId)).value(‘!00007*‘); queryRun = new QueryRun(query); if(queryRun.next()) { purchTable = queryRun.get(tableNum(PurchTable)); print purchTable.PurchId; pause; } Using NotExists join seems more complicated than the first option, but actually there is no performance difference between them. Источник: http://microsoft-dynamics-ax-erp.blo...namics-ax.html
| За это сообщение автора поблагодарили: alex55 (1). | |
