msdax: Date Range in AOT Query from SSRS
Источник: http://msdax.blogspot.com/2011/03/da...from-ssrs.html
============== [LEFT] Query: How can I add date ranges in an AOT query linked to SSRS. Answer: Kindly use the following sample code to create a data method and then use it as a source for report data set. [DataMethod(), AxSessionPermission(SecurityAction.Assert)] X++: public static DataTable GetData(DateTime fromDate, DateTime toDate) { DataTable table = new DataTable(); IDictionary myRanges = new Dictionary(); myRanges.Add("AOTTable.Date", fromDate.ToString("dd/MM/yyyy") + ".." + toDate.ToString("dd/MM/yyyy")); table = AxQuery.ExecuteQuery("select * from AOTQuery", myRanges); return table; } Источник: http://msdax.blogspot.com/2011/03/da...from-ssrs.html
Расскажите о новых и интересных блогах по Microsoft Dynamics, напишите личное сообщение администратору. Последний раз редактировалось Poleax; 01.04.2011 в 13:44. |
