A couple of weeks ago Microsoft Visual Studio 2010 was released. Unfortunately we will not be able to support Visual Studio 2010 in Dynamics NAV 2009 when developing SSRS (RDLC) reports.
When you are designing RDLC reports in NAV 2009 you are creating reports in a format known as the “RDL 2005” format. Both Visual Studio 2005 and 2008 supports this format, but not Visual Studio 2010. Visual Studio 2010 is able to open the “RDL 2005” format but will immediately convert the report to “RDL 2008” format. This conversion gives us the some challenges:
If you for other reasons want to use Visual Studio 2010 you can easily have Visual Studio 2008 and Visual Studio 2010 installed on the same machine. We will just open the Visual Studio 2008 version when you select “View / Layout” in the Object Designer. If you only have Visual Studio 2010 installed you will see this message: “An error occurred when opening Report Designer. A supported version of Visual Studio could not be found.“ This is the same message you get when you have no Visual Studio installed, because we search for the following Visual Studio versions and in prioritized order. So in case you have both Visual Studio 2005 and 2008 installed, we will use the 2008 version:
Hint: If you are using Windows 7 and want to use “Microsoft SQL Server 2008 Express with Advanced Services ” you need to install “Microsoft SQL Server 2008 R2 Express with Advanced Services” to have a successful installation. Thanks, Claus Lundstrøm, Program Manager, Microsoft Dynamics NAV Источник: http://feedproxy.google.com/~r/Micro...-nav-2009.aspx
