Старый 31.03.2022, 20:11   #1
daxrunbase: Finding objects marked for deletion
Источник: https://www.daxrunbase.com/2022/03/3...-for-deletion/
During our code upgrade we have identified that the SysDeletedObjects configuration keys were still turned on. Also many DEL_-prefixed fields were being referred or used in various places. We had to come up with a way for finding objects marked for deletion. The documentation gives you an idea of what to do with such elements. [...]
The post Finding objects marked for deletion appeared first on DAXRunBase.
daxrunbase: AOT property for kernel objects are readable via reflection Blog bot DAX Blogs 0 05.10.2018 19:12
daxrunbase: Change AOT objects without AX client Blog bot DAX Blogs 0 11.09.2018 16:11
sp-nav-tech: Export and Split Navision objects using Windows PowerShell in NAV 2015 Blog bot NAV: Blogs 0 16.08.2017 17:11
NAV Team: Merging Application Objects using Windows PowerShell in Microsoft Dynamics NAV 2015 Blog bot Dynamics CRM: Blogs 0 03.10.2014 14:30
NAV Team: Automation Objects in Microsoft Dynamics NAV 2009 Blog bot Dynamics CRM: Blogs 0 03.12.2008 17:27
Часовой пояс GMT +3, время: 04:35.
