Старый 14.12.2021, 23:11   #1
PowerShell and SQL scripts for Database Refreshing in a Devbox
Источник: http://alexvoy.blogspot.com/2021/12/...-database.html
Say you created a new database AxDB_TEST2 and restored a test environment backup there.
Now you need to change the databases names so that D365FO would target a restored data.
First, you need to stop D365FO services, for example, with a similar PowerShell script.
function StopD365RelevantService()
$services = "DynamicsAxBatch","Microsoft.Dynamics.AX.Framework.Tools.DMF.SSISHelperService.exe","MR2012ProcessService","LCSDiagnosticClientService"
foreach ($item in $services)
Set-Service -Name $item -StartupType Disabled
Stop-Service -Name Microsoft.Dynamics.AX.Framework.Tools.DMF.SSISHelperService.exe -ErrorAction SilentlyContinue
Stop-Service -Name DynamicsAxBatch -ErrorAction SilentlyContinue
Stop-Service -Name W3SVC -ErrorAction SilentlyContinue
Stop-Service -Name MR2012ProcessService -ErrorAction SilentlyContinue
Stop-Service -Name LCSDiagnosticClientService -ErrorAction SilentlyContinue
Set-Service -Name W3SVC -StartupType Automatic
Then you can use the following SQL script to 'exchange' two databases.
use master
ALTER DATABASE AxDB SET SINGLE_USER WITH ROLLBACK IMMEDIATE
ALTER DATABASE AxDB MODIFY NAME = AxDB_ORIG
ALTER DATABASE AxDB_ORIG SET MULTI_USER
ALTER DATABASE AxDB_TEST2 SET SINGLE_USER WITH ROLLBACK IMMEDIATE
ALTER DATABASE AxDB_TEST2 MODIFY NAME = AxDB
ALTER DATABASE AxDB SET MULTI_USER
Once it is done, get the services back to life
function StartD365RelevantService()
#Set-Service -Name "DynamicsAxBatch","Microsoft.Dynamics.AX.Framework.Tools.DMF.SSISHelperService.exe","W3SVC","MR2012ProcessService" -StartupType Automatic
$services = "DynamicsAxBatch","Microsoft.Dynamics.AX.Framework.Tools.DMF.SSISHelperService.exe","W3SVC","MR2012ProcessService","LCSDiagnosticClientService"
Set-Service -Name $item -StartupType Automatic
#Set-Service -Name 'DynamicsAxBatch' -StartupType Automatic
Start-Service -Name Microsoft.Dynamics.AX.Framework.Tools.DMF.SSISHelperService.exe -ErrorAction SilentlyContinue
Start-Service -Name DynamicsAxBatch -ErrorAction SilentlyContinue
Start-Service -Name W3SVC -ErrorAction SilentlyContinue
Start-Service -Name MR2012ProcessService -ErrorAction SilentlyContinue
Старый 17.12.2021, 12:38   #2
gl00mie is offline
gl00mie
3,684 / 5813 (201) ++++++++++
Спасибо, отличный скрипт, чтобы избежать некоторого ручного труда Правда, вспоминается при этом фраза из м/ф "Простоквашино" в эпизоде про фотоохоту на зайца:
Ты теперь еще за ним полдня бегать будешь - чтобы фотографию отдать...
Собственно, а почему бы тут не развить тему автоматизации переноса транзакционной базы D365FO между средами? Кто что еще вспомнит?
  • SID вашего пользователя и вообще наличие пользователя в базе. Допустим на минуточку, что тестовая среда и DevBox относятся к разным tenant-ам. Тогда даже при наличии "своей" учетки в принесенной базе, в таблице UserInfo, и наличии админской роли зайти в D365FO, скорее всего, не получится, потому что в другом тенанте у этой учетки будет другой SID. Тогда понадобится обновить провайдера и SID (если не хотим каждый раз гонять AdminUserProvisioning).
  • Зашифрованные строки подключения к ПБД из Data Management (Workspaces / Data Management / Configure entity export to database) надо заводить заново, потому что сертификат для шифрования данных вы вместе с базой, скорее всего, в свой DevBox не перенесли.
  • Зашифрованные пароли пользователя для некоторых типов источников DMF (Workspaces / Data Management / Configure datasource) слетели по той же причине.
  • Зашифрованный пароль для аутентификации на SMTP-сервере (System administration / Setup / Email / Email parameters / SMTP settings) слетел по той же причине.
  • Зашифрованные строки подключения для провайдеров валютных курсов (General ledger / Currencies / Configure exchange rate providers) слетели по той же причине.
  • Регистрации приложений AAD (System administration / Setup / Azure Active Directory applications), используемые при вызове извне сервисов D365FO, вероятно, потребуют изменений, если только в регистрациях для тестовой среды не был прописан URL вашей DevBox
  • Еще бы я лично выполнил truncate table для DatabaseLog, EventCUD, EventCUDLines, EventInbox, EventInboxData, SecurityObjectHistory, SysLastValue, SysClientSessions, SysServerSessions, SysSkipDatabaseLog, SysUserLog, а также для всяких там ParmLine/ParmTable/ParmUpdate-таблиц
Это вот из того, что вспомнилось и не имеет какой-то проектной специфики.
PS. а службу MR я в DevBox обычно отключаю - она только зазря ресурсы жрет и базу грузит
За это сообщение автора поблагодарили: sukhanchik (20), Logger (15).
Старый 20.12.2021, 18:32   #3
vmoskalenko is offline
vmoskalenko
Аватар для vmoskalenko
145 / 334 (12) ++++++
Это в две стандартных команды
Код:
#region Stop and Disable Management Reporter Service <--
Write-Host "Stop and Disable Management Reporter Service (Optional)" -ForegroundColor Yellow
Write-Host "..Stopping and Disabling Management Reporter Service" -ForegroundColor Yellow
Stop-Service -Name MR2012ProcessService -Force
Set-Service -Name MR2012ProcessService -StartupType Disabled
#endregion Stop and Disable Management Reporter Service -->
Старый 17.12.2021, 15:43   #4
trud is offline
trud
1,039 / 1635 (57) ++++++++
Записей в блоге: 1
А чем кстати не устроили d365fo.tools?
Т.е. многое из описанного в нем есть
https://github.com/d365collaborative...pac-Into-Tier1
За это сообщение автора поблагодарили: sukhanchik (10), gl00mie (3).
Старый 20.12.2021, 18:28   #5
vmoskalenko
Вот мои скрипты которые построены на базе d365fo.tools
https://github.com/valerymoskalenko/...rShell-scripts
msdynamicsworld: Azure Insights: ExpressRoute architecture; Arc-enabled SQL servers; Service Principal and PowerShell querying Blog bot DAX Blogs 0 19.10.2020 00:17
D365FO - Как обновить изображение баннера в юридическом лице используя SQL и PowerShell MarinaAX DAX: Администрирование 8 22.10.2018 22:06
jaestevan: PowerShell para la administración automática de Dynamics AX 2012 (PS-II) Blog bot DAX Blogs 0 28.06.2016 17:11
waldo: Invoke-NAVSQL: Execute SQL queries on NAV databases with PowerShell Blog bot NAV: Blogs 0 08.06.2016 03:17
Microsoft Dynamics CRM Team Blog: Microsoft Dynamics CRM and SQL Server 2012 - Better Together Blog bot Dynamics CRM: Blogs 0 08.03.2012 04:32
Часовой пояс GMT +3, время: 00:05.
