Старый 12.11.2021, 20:13   #1
d365technext: Data Management Project Using X++
Источник: https://d365technext.blogspot.com/20...t-using-x.html
Using the following code, you can import the file and execute the project using your x++ code.
In the code, I am making the file on runtime and uploading the file into temp storage for the demo purpose
but you can use the file uploader as per your requirement.
Code
class AD_Test
/// Runs the class with the specified arguments.
/// The specified arguments.
public static void main(Args _args)
FileUploadTemporaryStorageStrategy fileUploadStrategyInstance;
DMFDefinitionGroupEntity definitionGroupEntityBuffer;
DMFEntity dmfEntitybuffer;
FileUploadTemporaryStorageResult result;
SysDictClass uploadStrategyDictClassInstance;
str entityName = 'VendVendorGroupEntity';
System.IO.StreamWriter swriter;
System.IO.MemoryStream fileStream;
DMFExecutionId executionId;
#File
fileStream = new System.IO.MemoryStream();
swriter = new System.IO.StreamWriter(fileStream);
swriter.WriteLine("VENDORGROUPID,DESCRIPTION");
swriter.WriteLine(strFmt("%1,%2",'Ex-VendGroup','Example Vendor group'));
swriter.Flush();
uploadStrategyDictClassInstance = new SysDictClass(className2Id('FileUploadTemporaryStorageStrategy'));
fileUploadStrategyInstance = uploadStrategyDictClassInstance.makeObject() as FileUploadTemporaryStorageStrategy;
result = fileUploadStrategyInstance.uploadFile(fileStream, 'VendorsGroups.csv');
fileStream.Dispose();
CodeAccessPermission::revertAssert();
executionId = DMFUtil::setupNewExecution('ImportVendorGroup');
select firstonly Entity from definitionGroupEntityBuffer exists join dmfEntitybuffer
where definitionGroupEntityBuffer.DefinitionGroup == 'ImportVendorGroup' &&
dmfEntitybuffer.EntityName == definitionGroupEntityBuffer.Entity &&
dmfEntitybuffer.TargetEntity == entityName ;
DMFDefinitionGroupExecution executionBuffer = DMFDefinitionGroupExecution::find('ImportVendorGroup', definitionGroupEntityBuffer.Entity, executionId, true);
ttsbegin;
executionBuffer.FilePath = result.getFileId();
executionBuffer.IsTransformed = NoYes::Yes;
executionBuffer.update();
ttscommit;
DMFQuickImportExport::doPGImport('ImportVendorGroup', executionId, true);
sertandev: How to integrate with Dynamics 365 for Finance and Operations Blog bot DAX Blogs 0 21.08.2020 15:12
dynamicsaxse: November 2018 Release – Dynamics AX2012 R3 update Blog bot DAX Blogs 0 15.11.2018 09:11
patrickmouwen: 1yr with AX7 Data Management – My top 12 learnings Blog bot DAX Blogs 2 12.10.2016 15:14
emeadaxsupport: SEPA affected objects Blog bot DAX Blogs 0 29.11.2013 13:11
Часовой пояс GMT +3, время: 07:26.
