Старый 10.08.2019, 04:57   #1
How to filter existing transactions based on a financial dimension value set
Источник: http://alexvoy.blogspot.com/2019/08/...nsactions.html
Let's assume that we want to see our bank accounts balances grouped by a financial set, which may be different than that set up for your transactions.
For example, existing transactions presume to have values for the following dimension attributes.
However, our selection can be different. For this exercice sake I opted for Business unit and Department.
So, instead of one balance for the whole bank account, we want to get it distributed per every combination of Business unit and Department values.
Another point to consider is the fact that these attributes are not mandatory; in other words, we don't have values for all attributes in all transactions.
It can be easily achieved if we find a way to create a column with all sought dimension attribute values concatened as depicted.
Generally speaking this is a job a BI solution; however, it is possible to do in D365 by means of Views.
Let's solve this problem step by step.
Fisrt view is for all selected attributes that we should populate values for, exist them or not.
Second, collect all existing values which match our selected attributes.
Then, group all found dimension attribute sets.
Now we create a view based on the latter and sought attributes without relation in outer join. By that we will get a Carthesian product of all possible combinations between them.
At this step we outer join the latter with the found (existing) values. Here we can add a computed column if we want to see something else than just an empty value.
private static server str displayValueWithNA() // X++
str sRet;
tableName viewName = viewstr(CDPDimensionAttributeValuesUnionView);
str cDisplayValue = SysComputedColumn::comparisonField(viewName,
viewstr(CDPDimensionAttributeValuesSelectedView),
fieldStr(CDPDimensionAttributeValuesSelectedView, DisplayValue));
sRet =
SysComputedColumn::if(SysComputedColumn::isNotNullExpression(cDisplayValue),
cDisplayValue,
SysComputedColumn::returnLiteral('n/a')
return sRet;
Final view will contain all the values found on the previous step grouped by dimension attribute value set so that in a computed column all values be concatened in the required order.
private static server str finDimValues() // X++
return @"STUFF((SELECT '-' + t3.DisplayValue
from CDPDimensionAttributeValuesUnionView as t3
where
t1.DimensionAttributeValueSet = t3.DimensionAttributeValueSet
order by t3.DIMENSIONATTRIBUTE
for xml path('')), 1, 1, '')";
Having this view in inner join combination allows you to filter any transactional data by a set of dimenions without coding.
Старый 10.08.2019, 12:50   #2
прежде всего, огромное спасибо.
Сообщение от Blog bot Посмотреть сообщение
это замечательно. но похоже, пример раскрывает как отфильтровать две ПОСЛЕДОВАТЕЛЬНЫЕ позиции. причем ничего не говорится, что в этих позициях могут находится и другие аналитики.
я думаю, что в статье обязательно требуется рассмотреть случай, когда в одной позиции могут находится несколько разных аналитик, в списке которых есть одинаковые значения. я навскидку уже не помню, но в демопримере был случай, когда во вторую позицию с одними счетами прибылей и убытков могли записываться либо CostCenter, а в другие счета прибылей и убытков во вторую позицию могли записываться Purpose. Или нечто подобное. Причем в обоих списках были значения 010.
возвращаясь к статье:
разбирать аналитики на примере банковских проводок - не очень. либо надо обосновать каким образом на банковских проводках могут возникнуть разные комбинации аналитик.
для каждой view стоит привести пример данных. Особенно для таких "By that we will get a Carthesian product of all possible combinations between them".
очень хотелось бы статью, в которой раскрывались бы решения для следующих обыденных задач:
задача 1: отфильтровать проводки по счетам прибылей и убытков с CostCenter = 010. В какой бы позиции не находился CostCenter. При условии, что эти же позиции могут занимать другие аналитики И в этих других аналитиках также может существовать значение 010.
задача 1': то же самое, что в задаче 1, только CostCenter = 01*.
задача 1'': то же самое, что в задаче 1, только CostCenter = 01*..02*,!021.
задача 2: отфильтровать проводки по счетам прибылей и убытков с CostCenter = 010 и Department = 010. В какой бы позиции не находились CostCenter и Department. При условии, что эти же позиции могут занимать другие аналитики И в этих других аналитиках также может существовать значение 010.
задача ***: отфильтровать с условием "или". в запросах по остальным значениям (не финансовая аналитика) в поисковом выражении можно использовать скобки.
https://axapta.mazzy.ru/lib/search/
Примечание: можно посмотреть в 1С:Бухгалтерию, в которой задача выборки по субконто давно решена. можно также рассказать какой ценой решили эту задачу в 1С:Бухгалтерии.
опять же - и Business unit, и Department может находится в разных позициях в разных проводках.
в том числе, в некоторых случаях сначала может идти Business unit, а затем Department. а в некоторых - сперва Department, а затем Business unit. Причем между этими аналитиками могут быть расположены другие аналитики.
статья о фильтрации по чудо-финансовым-аналитикам без рассмотрения таких случаев не может трактоваться как полезная.
му-ха-ха-ха!!!
ни в коем случае не хочу принижать достоинства статьи и изложенного подхода.
Хочу сказать лишь одно - архитекторы, которые это чудо задолжили в Аксапту... они как собирались выполнять фильтрацию? какой способ по их мнению должны были использовать пользователи?
приходит такой пользователь и спрашивает "как отфильтровать по CostCenter"
а архитектор отвечает - "нет-нет, ты еще не готов к этому" https://coub.com/view/1avfh5
а для продвинутых програмеров-в-закрытой-системе он начинает ответ с фразы "Let's solve this problem step by step..."
Now we create a view based on...
е-е-е-е-е!!!!
we - это пользователи? или программисты?
сколько таких вью должны создать программисты в закрытой системе, чтобы пользователи хотя бы перестали ругаться?
...without relation in outer join
серьезно?
и сколько значений сможет обслуживать этот подход к фильтрации?
можно ли вводить значения как критерий через запятую? со звездочкой? а с другими мета символами?
фиг с ними, с пользователями.
если использовать этот подход программно, то из кода сколько значений для фильтрации предполагается?
    str         sRet;
    sRet =
                                cDisplayValue,
    return sRet;
серьезно?
опять же со всем восхищением к изворотливости ума.
но задача тривиальной фильтрации действительно требует вот такого кода?
where
серьезно?!
Последний раз редактировалось mazzy; 10.08.2019 в 13:37.
Старый 10.08.2019, 14:03   #3
trud is offline
trud
1,039 / 1635 (57) ++++++++
Записей в блоге: 1
серьезно?!
Картинка прямо в тему
А чем для задачи Financial dimension sets не подошли, они вроде как раз для группировки нужны(если я правильно понял проблему)
Старый 10.08.2019, 14:57   #4
понятия не имею. кстати, тоже бы посмотрел на ответ.
а вот пользователи точно НЕ формулируют свои вопросы в терминах Financial dimension sets
с удовольствием послушаю как можно применить Financial dimension sets в ответе на вопрос "как отфильтровать по CostCenter"
Старый 10.08.2019, 21:55   #5
wojzeh is offline
wojzeh
Аватар для wojzeh
681 / 517 (19) +++++++
да никак. в том-то и пуля, что в транзакциях один набор используется, а пользователю хочется другой.
дополнительная проблема в том, что не для всех атрибутов есть наборы значений (затем и нужен тут тов. Декарт)
Felix nihil admirari
Старый 10.08.2019, 15:02   #6
и кстати, не соглашусь.
подход в статье очень интересный и хитроумный.
другое дело, что даже для proof of concept с такой фин.аналитикой нужно быть еще хитроумнее.
беда в том, что в ax2012 и выше для ответа тривиальный вопрос про фильтрацию по фин.аналитике требуется очень хитроумный ответ программиста.
Financial dimension values concatened by mask
Последний раз редактировалось mazzy; 10.08.2019 в 15:06.
Старый 10.08.2019, 21:40   #7
wojzeh is offline
wojzeh
Аватар для wojzeh
на здоровье! может, стоит слить оба топика, а то и так мозг плавится, а тут два треда получились?
твоё замечание я не понял, извини. что меняется, от того, последовательные они или нет? выборка идёт по всем наборам, так как они и использованы в транзакциях. в каждом наборе заданы атрибуты и их значения. какая нам разница, в каких они позициях? ты посмотри структуру всех вьюх, там всё ровно так, как оно и используется в аксе - никакой самодеятельности.
решается задача, разумеется, группировки сальдо по выбранным значениям измерений (фильтрация по выбранному набору атрибутов), и никакой фильтрации по собственно значениям тут нет - это может делать уже сам пользователь в броузере.
см. выше. пофиг на значения, они не сравниваются.
сделал. хотя не очень понимаю, чем облегчит муки и страдания.
похоже, я точно что-то важное пропускаю с этими "позициями"... можешь попробовать прикрутить предложенное решение к таблице с твоими проводками и проверить, как оно работает? дать тебе проектик, чтоб не колупать руками?
это уже выкрутасы с собственно фильтрами. думаю в сторону регулярных выражений. на той выборке, которую дают мои вьюхи можно измываться уже с готовой строкой аналитик, как душеньке угодно.
ну, там можно много чего посмотреть, как можно было сделать в аксе. я с того свою забугорную карьеру и начал. пришёл на первое собеседование и сразу им сказал, что аксапту не знаю, но щас вам, парни, расскажу, как всё круто сделано в 1С. они меня и взяли сразу
ну, мы по кругу ходить не будем. это же одно и то же ты повторил многократно. если не работает, то приведи мне пример, где оно не так работает?
му-ха-ха-ха!!!
да там не му-ха-ха! там гы-ы-ы-ы! потому что ты ещё не видел running totals по всем датам!
это оч хороший вопрос. ау? где вы, архитекторы? я бы тоже с удовольствием послушал. по-моему, тут же была пара светлых голов, которые писали статьи на эту тему? trud?
е-е-е-е-е!!!!
разумеется, мы - программисты (народ мускулистый)
серьезно?
какие тебе видятся проблемы с масштабированием? в каком именно месте?
куда ты собрался вводить? в постановке задачи можно лишь выбрать набор атрибутов (Dimension set)
не понял вопроса.
серьезно?
а как ещё можно получить все возможные комбинации, как ни всех на всех перемножить? нормальный вариант, но нужно примерно представлять масштабы бедствия перед такими ковровыми бомбардировками. в моём случае всех значений всего 3500. перемножить на 2,3,....12 атрибутов - не бог весть какая беда.
ещё разок: тут задача группировки, во-первых, а во-вторых, фильтрации по выбранным атрибутам, а не по значениям.
серьезно?!
в аксе есть табличка со значениями выбранных атрибутов в столбцах, которые можно легко слепить в одну строку, но... ты просто загляни в неё... только сядь, если стоишь, а лучше ляг. я не в состоянии придумать динамический подход к этой подзадаче. поэтому просто провернул этот фокус с прямым запросом в сикеле. видимо, сказывается сертификация в QlikView.
моей первой реакцией на эту задачу было вынести всё это из аксапты к свиньям собачьим (то есть, в какой-нибудь там PowerBI или т.п.), но архитектор сказал "don't ссы и делай всё тута". ну, вот я и сделал.
спасибо за дискуссию. интересно обсудить этот сюжет с двух сторон: как вообще юзера должны управляться с измерениями, и как можно улучшить (или даже исправить косяки) этого конкретного решения.
Последний раз редактировалось wojzeh; 10.08.2019 в 21:51.
За это сообщение автора поблагодарили: mazzy (93).
Старый 25.09.2019, 16:33   #8
wojzeh is offline
wojzeh
Аватар для wojzeh
серьезно?
серьезно?!
нам тут не до шуток!!! я тут вот заглянул в стандартный DimensionSetEntity, а там... а там... а там вот чо:
 ///  Each enterprise can expose different dimension attributes.  Therefore, we have determine what dimension attributes
    ///  columns are exposed, then concatenate the fields separated by the account delimiter.
    ///  Example: dimensionField1 - + dimensionField2 - + dimensionField3 ...
    /// </remarks>
    private static server str displayValue()
        str displayValueSql;
        str accountDelimiterSql;
        str dimensionValueColumns;
        str accountDelimiterEscapedSql;
        SysDictEnum delimiterDictEnum = new SysDictEnum(enumnum(DimensionSegmentDelimiter));
        int enumValue = delimiterDictEnum.firstValue();
        for (int i = 1; i <= delimiterDictEnum.values(); i++)
            str enumLabel = delimiterDictEnum.index2Label(enumValue);
            accountDelimiterSql += strfmt(
                "WHEN %1 THEN '%2'\n", delimiterDictEnum.index2Value(enumValue), enumLabel);
            accountDelimiterEscapedSql += strfmt(
                "WHEN %1 THEN '%2'\n", delimiterDictEnum.index2Value(enumValue), DimensionSetEntity::generateEscapedDelimiter(enumLabel));
            enumValue = delimiterDictEnum.nextValue(enumValue);
        // Get the list of all dimension attributes that have metadata columns
        dimensionValueColumns = DimensionSchemaAndDataSynchronizationUtility::getSynchronizedDimensionValueColumnNames(
            tablestr(DimensionAttributeValueSet));
        if (strLen(dimensionValueColumns) == 0)
            // No table extension columns.
            displayValueSql = SysComputedColumn::returnLiteral('');
        else
            str errorMessage = strReplace("@Dimension:DimensionEntitiesDimensionStructureNotCreated", "'", "''");
            LanguageId systemLanguageId = SystemParameters::find().SystemLanguageId;
            // Determine the error message based on system language
            if (systemLanguageId != '')
                errorMessage = strReplace(SysLabel::labelId2String2("@Dimension:DimensionEntitiesDimensionStructureNotCreated", systemLanguageId), "'", "''");;
            //Create view sql
            displayValueSql = strfmt(
                SELECT (
                   SELECT CASE WHEN
                            NonNullDisplayValue IS NOT NULL
                            THEN NonNullDisplayValue
                            ELSE '%4'
                        END
                        FROM
                        -- Remove initial delimiter
                        SELECT STUFF(
                            (SELECT
                                    -- Prepend with delimiter and escape internal delimiters
                                    DIMENSIONSEGMENTDELIMITER + COALESCE(
                                        REPLACE(REPLACE(DIMLIST.DISPLAYVALUE, '\', '\\'),
                                                DIMENSIONSEGMENTDELIMITER,
                                                DIMENSIONSEGMENTDELIMITERESCAPED),
                                FROM
                                    (SELECT TOP (1) DH.RECID
                                        FROM DIMENSIONHIERARCHY DH
                                        JOIN DIMENSIONHIERARCHYINTEGRATION DHI
                                            ON DHI.DIMENSIONHIERARCHY = DH.RECID
                                            AND DHI.ISDEFAULT = 1
                                            AND DHI.PARTITION = T1.PARTITION
                                        WHERE
                                            DH.PARTITION = T1.PARTITION
                                            AND DH.STRUCTURETYPE = %2
                                    ) AS DH
                                JOIN DIMENSIONHIERARCHYLEVEL DHL
                                    ON DHL.DIMENSIONHIERARCHY = DH.RECID AND DHL.PARTITION = T1.PARTITION
                                JOIN DIMENSIONATTRIBUTE DA
                                    ON DA.RECID = DHL.DIMENSIONATTRIBUTE AND DA.PARTITION = T1.PARTITION
                                LEFT JOIN
                                        (SELECT DIMENSIONATTRIBUTE, DISPLAYVALUE
                                            FROM
                                                (SELECT * FROM DIMENSIONATTRIBUTEVALUESET DAVS
                                                    WHERE DAVS.PARTITION = T1.PARTITION AND DAVS.RECID = T1.RECID) P
                                            UNPIVOT
                                                (DISPLAYVALUE for DIMENSIONATTRIBUTE IN (%3))
                                                        AS DIMENSIONVALUECOLUMNNAME
                                        ) AS DIMLIST
                                    ON
                                        DIMLIST.DIMENSIONATTRIBUTE = REPLACE(DA.DIMENSIONVALUECOLUMNNAME COLLATE Database_Default, '.', '$')
                                ORDER BY DHL.DIMENSIONHIERARCHY, DHL.LEVEL_
                                FOR XML PATH(''), TYPE
                            ).value('(./text())[1]', 'NVARCHAR(MAX)'),
                            1, LEN(DIMENSIONSEGMENTDELIMITER), '')
                         AS NonNullDisplayValue)
                    AS DisplayValueFormat)
                    FROM
                        (SELECT TOP(1)
                                --Determine the account delimiter
                                CASE DIMENSIONSEGMENTDELIMITER
                                    %1
                                END AS DIMENSIONSEGMENTDELIMITER,
                            --Determine the account delimiter escaped
                                %5
                            END AS DIMENSIONSEGMENTDELIMITERESCAPED
                        FROM DIMENSIONPARAMETERS
                        WHERE DIMENSIONPARAMETERS.PARTITION = T1.PARTITION
                    ) AS DIMENSIONPARAMETERS
                accountDelimiterSql,
                enum2int(DimensionHierarchyType::DataEntityDefaultDimensionFormat),
                dimensionValueColumns,
                errorMessage,
                accountDelimiterEscapedSql);
        return displayValueSql;
Старый 12.08.2019, 14:17   #9
fed is offline
fed
Аватар для fed
Ex AND Project
2,913 / 5736 (197) ++++++++++
Возможно, я невнимательно читал дискуссию, но ведь в D365FO значения аналитик продублированы в динамические (то есть - не видимые в AOD и создаваемые во время настроек ГК) поля в таблицах DimensionAttributeValueSet (для default dimensions) и DimensionAttributeValueCombination (для LedgerDimension) ). FieldId этих полей можно получить через вызовы функций, а потом добавить в query или в calculated field во view.
Например:
FieldId costcenterFieldId = DimensionAttributeValueSet::getDimensionValueFieldId('COSTCENTER'); //fieldId аналитики costCenter для default Dimension
FieldId costCenterFieldId = DimensionAttributeCombination::getDimensionValueFieldId('COSTCENTER'); //fieldId аналитики costCenter для Ledger dimension
DimensionAttributeCombination::getDimensionKeyFieldId('COSTCENTER'); //fieldId поля со ссылкой по recId на значение аналитики costCenter для LedgerDimension.
После того как fieldId получен можно эти таблицы заджойнить например с custTable (для dimensionAttributeValueSet) или с GeneralJournalAccountEntry (для DimensionAttributeCombination), потом создать range по fieldId и поискать по условию !"".
Второй вариант я не пробовал, но dimensionAttributeValueSet с custTable и vendTable я джойнил и значение аналитики через calculated field во view вытаскивал. Работает без проблем, фильтрует, сортирует, группирует и тп (поскольку это обычное поле, сделанное почти как в DAX2009).
Последний раз редактировалось fed; 12.08.2019 в 15:05.
За это сообщение автора поблагодарили: trud (5).
Старый 12.08.2019, 15:59   #10
почему fieldid один?
насколько я помню, их может быть насколько в зависимости от того какой dimSet используется.
насколько я помню, в том то и проблема, что эта финансовая аналитика была устроена как субконто в 1С:Бухаглтерии, а не как InventDim в Аксапте. Другими словами, не было таблицы в которой в одной колонке были бы значения одной финансовой аналитики.
конечно могу сильно ошибаться, поскольку уже давно в новые аксапты не заглядывал. очень хочется увидеть статьи на тему - как легко делать выборку финансовой аналитики в интерфейсе пользователя, в программном коде X++, а также из внешних систем (SQL запрос, MDX-запрос, C# и прочее). Ну, или хоть как-нибудь.
Последний раз редактировалось mazzy; 12.08.2019 в 16:01.
Старый 12.08.2019, 16:20   #11
fed is offline
fed
Аватар для fed
Ex AND Project
Ну вот сейчас (то есть - по крайней мере начиная с D365FOE 7.30, но вероятно и с более ранних версий), все сделано именно как inventDim. То есть - в дополнение к хитромудрым таблицам DAX2012, в таблички, на которые ссылаются DefaultDimension и ledgerDimension добавлены поля со значениями аналитик.
Поэтому, для настройки аналитик, система требует входа в Maintanance Mode (просто чтобы не добавлять новые поля, когда другие пользователи работают)
Старый 12.08.2019, 16:42   #12
wojzeh is offline
wojzeh
Аватар для wojzeh
и как это помогает решит поставленную задачу?
Старый 12.08.2019, 15:29   #13
raz is offline
raz
NavAx
Аватар для raz
NavAx Club
1,499 / 1097 (39) ++++++++
https://community.dynamics.com/ax/f/...ensions-in-ax7
    private void test()
        GeneralJournalAccountEntry          generalJournalAccountEntry;
        GeneralJournalEntry                 generalJournalEntry;
        DimensionAttributeValueCombination  dimensionAttributeValueCombination;
        Query                               query = new Query();
        QueryRun                            queryRun;
        QueryBuildDataSource                qbds1, qbds2, qbds3;
        str                                 strData;
        qbds1 = query.addDataSource(tableNum(GeneralJournalAccountEntry));
        qbds1.addSelectionField(fieldNum(GeneralJournalAccountEntry, TransactionCurrencyAmount), SelectionField::Sum);
        qbds1.addSelectionField(fieldNum(GeneralJournalAccountEntry, AccountingCurrencyAmount), SelectionField::Sum);
        qbds1.addGroupByField(fieldNum(GeneralJournalAccountEntry, TransactionCurrencyCode));
        qbds2 = qbds1.addDataSource(tableNum(GeneralJournalEntry));
        qbds2.relations(false);
        qbds2.addLink(fieldNum(GeneralJournalAccountEntry, GeneralJournalEntry), fieldNum(GeneralJournalEntry, RecId));
        qbds2.fetchMode(QueryFetchMode::One2One);
        qbds2.addGroupByField(fieldNum(GeneralJournalEntry, AccountingDate));
        qbds2.addGroupByField(fieldNum(GeneralJournalEntry, SubledgerVoucherDataAreaId));
        qbds3 = qbds1.addDataSource(tableNum(DimensionAttributeValueCombination));
        qbds3.relations(false);
        qbds3.addLink(fieldNum(GeneralJournalAccountEntry, LedgerDimension), fieldNum(DimensionAttributeValueCombination, RecId));
        qbds3.fetchMode(QueryFetchMode::One2One);
        qbds3.addGroupByField(fieldName2Id(tableNum(DimensionAttributeValueCombination), identifierStr(MainAccountValue)));
        qbds3.addGroupByField(fieldName2Id(tableNum(DimensionAttributeValueCombination), identifierStr(BusinessUnitValue)));
        qbds3.addGroupByField(fieldName2Id(tableNum(DimensionAttributeValueCombination), identifierStr(LegalEntityValue)));
        qbds3.addGroupByField(fieldName2Id(tableNum(DimensionAttributeValueCombination), identifierStr(DepartmentValue)));
        queryRun = new QueryRun(query);
        while (queryRun.next())
            generalJournalAccountEntry         = queryRun.get(tableNum(GeneralJournalAccountEntry));
            generalJournalEntry                = queryRun.get(tableNum(GeneralJournalEntry));
            dimensionAttributeValueCombination = queryRun.get(tableNum(DimensionAttributeValueCombination));
            strData = strFmt('%1;%2;%3;%4;%5;%6;%7;%8;%9;',
                generalJournalAccountEntry.TransactionCurrencyAmount,
                generalJournalAccountEntry.AccountingCurrencyAmount,
                generalJournalAccountEntry.TransactionCurrencyCode,
                generalJournalEntry.AccountingDate,
                generalJournalEntry.SubledgerVoucherDataAreaId,
                dimensionAttributeValueCombination.(fieldName2Id(tableNum(DimensionAttributeValueCombination), identifierStr(MainAccountValue))),
                dimensionAttributeValueCombination.(fieldName2Id(tableNum(DimensionAttributeValueCombination), identifierStr(BusinessUnitValue))),
                dimensionAttributeValueCombination.(fieldName2Id(tableNum(DimensionAttributeValueCombination), identifierStr(LegalEntityValue))),
                dimensionAttributeValueCombination.(fieldName2Id(tableNum(DimensionAttributeValueCombination), identifierStr(DepartmentValue))),
Старый 12.08.2019, 15:35   #14
Сообщение от raz Посмотреть сообщение
группировка по валюте?
Старый 12.08.2019, 16:38   #15
raz is offline
raz
NavAx
Аватар для raz
NavAx Club
Это был тестовый Job, что бы поверить, рабочий вариант не такой.
Старый 12.08.2019, 16:44   #16
wojzeh is offline
wojzeh
Аватар для wojzeh
мой-то вариант чем не рабочий?
Старый 12.08.2019, 15:40   #17
Я правильно понимаю, что сейчас есть таблица, устроенная подобно InventDim, в которой каждое значение аналитики находится в своей колонке. а в GeneralJournalAccountEntry указывается идентификатор, подобный InventDim?
Старый 12.08.2019, 16:41   #18
wojzeh is offline
wojzeh
Аватар для wojzeh
ага. на-ка вот, насладись красотой!
открываешь такой это чудо-юдо в бровзере, а там - хоба-на!
круче, чем у копперфильда, разрезающего амаяка акопяна!
а поиск идёт по имени столбца
/// <summary>
    /// Gets the Value fieldId of the <c>DimensionAttributeValueCombination</c> table for a <c>DimensionAttribute</c> name.
    /// </summary>
    /// <param name = "_dimensionAttributeName">The name of the <c>DimensionAttribute</c>.</param>
    /// <returns>The Id of the Value field.</returns>
    public static FieldId getDimensionValueFieldId(Name _dimensionAttributeName)
        container cachedResult = DimensionCache::getValue(DimensionCacheScope::DimensionKeyValueColumn, [DimensionMetadataConstants::DimensionCombinationValueColumn, _dimensionAttributeName]);
        if (cachedResult == conNull())
            DimensionAttribute dimensionAttribute = DimensionAttribute::findByName(_dimensionAttributeName);
            if (!dimensionAttribute)
                throw error(Error::wrongUseOfFunction(funcName()));
            if (dimensionAttribute.getStatus() == DimensionAttributeStatus::Inactive)
                throw error("@Dimension:DimensionAttributeInactive");
            cachedResult = [fieldName2id(tableNum(DimensionAttributeValueCombination), dimensionAttribute.DimensionValueColumnName)];
            DimensionCache::insertValue(DimensionCacheScope::DimensionKeyValueColumn, [DimensionMetadataConstants::DimensionCombinationValueColumn, _dimensionAttributeName], cachedResult);
        FieldId dimensionAttributeFieldId = conpeek(cachedResult, 1);
        return dimensionAttributeFieldId;
Старый 12.08.2019, 16:28   #19
fed is offline
fed
Аватар для fed
Ex AND Project
Гм. Пожалуй вот здесь вот есть наиболее полный пример работы с новым методом доступа к аналитике.
Старый 12.08.2019, 16:48   #20
wojzeh is offline
wojzeh
Аватар для wojzeh
New dimension fields are added when a dimension is activated.
и как это возможно отловить в рамках поставленной задачи? (хинт: никак)
How to lookup and set a new value for Financial dimension Blog bot DAX Blogs 0 03.10.2015 02:35
emeadaxsupport: How to change the Storage dimension group on items with existing Inventory transactions Blog bot DAX Blogs 0 01.10.2015 21:11
NAV Team: Filtering on Dimension Values Blog bot Dynamics CRM: Blogs 0 12.06.2012 18:02
Khue Trinh: Setting up a link between a financial dimension and the site inventory dimension Blog bot DAX Blogs 0 27.09.2010 13:05
Часовой пояс GMT +3, время: 06:39.
