a33ik: Skip CIL execution
Источник: http://daxonline.org/1650-skip-cil-execution.html
============== To skip CIL execution for processes, which use SysOperation framework (SysOperationServiceController) - set break point to \Classes\SysOperationServiceController\runOperation and track how many parameters do you have to identify which serviceClass.callObject to modify - identify the type of proxy variable In my case proxy is of type FormletterService and I have only one parameter, method returns value - notice value of methodName variable to identify which method to call on the object, in my case it is postSalesOrderPackingSlip - declare new variable of real proxy type, in my case it is FormletterService FormletterService formletterService;- afteryour serviceClass.callObject write additional code like this one (depending onparameters count, return value and method to call) if (false) { formletterService = proxy; operationReturnValue = formletterService.postSalesOrderPackingSlip(o1); } - set break point to serviceClass.callObject - in debugger move execution cursor inside your if statement If execution of process if marshaled under specific user usingSysOperationRPCFrameworkService::runServiceOperation Two solutions for that 1. Set break poin to \Classes\SysOperationServiceController\run In debugger move execution cursor to one of the this.runOperation(false/*sync*/); 2. Modify \Classes\SysOperationRPCFrameworkService\runServiceOperation tothe following look: public static container runServiceOperation(ClassId controllerClassId, container packedController){ // Use the runas API to transition to a CLR session new XppILExecutePermission().assert(); /* TODO: temp solution to debug issue return SysDictClass::invokeStaticMethodIL(classStr(SysOperationServiceController), staticMethodStr(SysOperationServiceController, runServiceOperation), [controllerClassId, packedController]); */ return SysOperationServiceController::runServiceOperation([controllerClassId, packedController]);} Источник: http://daxonline.org/1650-skip-cil-execution.html |
Опции просмотра | |
