Старый 08.04.2019, 16:11   #1
palleagermark: Workaround to new error during import of security setup
Источник: https://www.agermark.com/2019/04/wor...ng-import.html
As a new feature to the security setup export and import, Microsoft has added information about objects being disabled/deleted, so the receiving system is able to pick that up too.
But if you both update an object and then disable it, you have created a combination of actions that cannot be imported. This is the error you'll get during import:
The technical reason reason is that the import deals with deleting/disabling objects before it deals with the updates. So when it gets to the update part, it cannot find the object.
The workaround is to pull out your best scissor software and cut out the update part of the XML. Here is an example where I have tried this with the TestEssentialsRole role:
Surprisingly to me is that this, according to MS support, works exactly as designed.
alexef: Sample Extension v2.0 — Dynamics NAV / AL extension / SaaS — ALF Export Setup Tabs to Excel Blog bot NAV: Blogs 3 05.10.2018 23:13
NAV Team: How to: Enable Import/Export of Bank or Payroll Files Using the Data Exchange Framework Blog bot Dynamics CRM: Blogs 0 18.10.2013 02:33
DynamicsAxSCM: Import vendor catalogs: from setup to importing a sample catalog – Part 2 (Importing a sample catalog) Blog bot DAX Blogs 0 09.09.2012 20:15
DynamicsAxSCM: Import vendor catalogs: from setup to importing a sample catalog – Part 1 (Setup) Blog bot DAX Blogs 0 30.08.2012 02:14
Inside Dynamics AX 4.0: The Security Framework Blog bot DAX Blogs 0 31.10.2007 11:40
Часовой пояс GMT +3, время: 18:16.
