Старый 28.03.2019, 03:33   #1
crmtipoftheday: Tip #1242: Invalid App SiteMap
Источник: https://crmtipoftheday.com/1242/invalid-app-sitemap/
After an update, you can’t get into your model driven app. The error says “Invalid App Site Map.”
To fix this, open the app in app designer.
Click the pencil to open Site Map Designer.
Make some kind of update to the SiteMap–if you don’t want to rearrange the subareas you can simply edit the name of one of the areas or groups, then change it back to what it was.
Save and publish your sitemap, then save and publish your model driven app.
Problem solved!
Cover photo by Muhammad Haikal Sjukri
crmtipoftheday: Tip #1224: Prebuild your embedded canvas app Blog bot Dynamics CRM: Blogs 0 01.03.2019 17:11
crmtipoftheday: Tip #1194: When the App for Outlook shows a random dashboard Blog bot Dynamics CRM: Blogs 0 16.11.2018 16:11
crmtipoftheday: Tip #1163: Set App Home Page Blog bot Dynamics CRM: Blogs 0 30.08.2018 14:11
crmtipoftheday: Tip #1131: Add some vector finesse to your Unified Interface App Blog bot Dynamics CRM: Blogs 0 11.07.2018 16:11
crmtipoftheday: Tip #1016: App Designer and disabled sitemap subareas in Dynamics 365 Blog bot Dynamics CRM: Blogs 0 06.11.2017 10:12
Часовой пояс GMT +3, время: 05:57.
