Старый 09.08.2018, 17:11   #1
d365technext: Customization Analysis Report D365FO
Источник: http://d365technext.blogspot.com/201...rt-d365fo.html
What is the Customization Analysis Report?
The Customization Analysis Report is a tool that analyzes your customization and extension models, and runs a predefined set of best practice rules. The report is one of the requirements of the solution certification process. The report is in the form of a Microsoft Excel workbook.
Source Link
How to generate the report
To generate the Customization Analysis Report, run the following command in a development environment.
xppbp.exe -metadata= -all -model= -xmlLog=C:\BPCheckLogcd.xml -module= -car=
Open Command Prompt and run the below script... please change the path as per your environment folder hierarchy.
CD C:\AOSService\PackagesLocalDirectory\Bin
I have 4 Sub model in my Main module... You can check in below screenshot.
Module
  1. SLDTaxationSuite
Model
  1. SLD_Taxation_Suite
  2. SLD_Ext_Common_Resource_PAK
  3. SLD_Ext_Taxation_PAK
  4. SLD_Ext_Taxation_Reports_PAK
So I need create 4 different script for all model...
Model : SLD_Taxation_Suite
xppbp.exe -metadata=C:\AOSService\PackagesLocalDirectory -all -model="SLD Taxation Suite" -xmlLog=C:\Car\Log\BPCheckLog_SLD_Taxation_Suite.xml -module="SLDTaxationSuite" -car=c:\CAR\SLD_Taxation_Suite.xlsx
Model : SLD_Ext_Common_Resource_PAK
xppbp.exe -metadata=C:\AOSService\PackagesLocalDirectory -all -model="SLD Ext Common Resource PAK" -xmlLog=C:\Car\Log\BPCheckLog_SLD_Ext_Common_Resource_PAK.xml -module="SLDTaxationSuite" -car=c:\CAR\SLD_Ext_Common_Resource_PAK\SLD_Ext_Common_Resource_PAK.xlsx
Model : SLD_Ext_Taxation_PAK
xppbp.exe -metadata=C:\AOSService\PackagesLocalDirectory -all -model="SLD EXT TAXATION PAK" -xmlLog=C:\Car\Log\BPCheckLog_SLD_EXT_TAXATION_PAK.xml -module="SLDTaxationSuite" -car=c:\CAR\SLD_EXT_TAXATION_PAK\SLD_EXT_TAXATION_PAK.xlsx
Model : SLD_Ext_Taxation_Reports_PAK
xppbp.exe -metadata=C:\AOSService\PackagesLocalDirectory -all -model="SLD Ext Taxation Reports PAK" -xmlLog=C:\Car\Log\BPCheckLog_SLD_Ext_Taxation_Reports_PAK.xml -module="SLDTaxationSuite" -car=c:\CAR\SLD_Ext_Taxation_Reports_PAK\SLD_Ext_Taxation_Reports_PAK.xlsx
Please feel free to contact me if you are facing any issue during following above blog.
d365technext: Vendor Aging Report D365FO Blog bot DAX Blogs 1 29.08.2018 14:00
newdynamicsax: Customization Analysis Report: Exceptions and known issues Blog bot DAX Blogs 0 25.04.2016 15:11
ax-erp: Walkthrough: Creating a Report Bound to a Report Data Provider Class (X++ Business Logic) [AX 2012] Blog bot DAX Blogs 0 20.09.2012 11:11
Часовой пояс GMT +3, время: 10:02.
