Старый 15.02.2018, 22:11   #1
axinthefield: Using the Systest framework and Task Recorder in Dynamics 365 for Finance and Operations to create integration tests
Источник: https://blogs.msdn.microsoft.com/axi...gration-tests/
Introduction How to create good validation tests for your implementation. The scenario is – ‘You have an ISV who delivers you updates and you want to have an automatic validation that proves nothing has been broken’. In the test automation pyramid the tests described in this post are typically called ‘integration tests’. A quick search...
stoneridgesoftware: Batch Processing in Dynamics AX 2012 Using SysOperation Framework Blog bot DAX Blogs 0 28.03.2017 00:11
Inside Dynamics AX 4.0: RunBase Framework Extension Part I Blog bot DAX Blogs 0 30.09.2007 09:20
Часовой пояс GMT +3, время: 16:08.
