Старый 13.12.2017, 19:11   #1
palleagermark: Find standard label translations
Источник: http://www.agermark.com/2017/12/find...nslations.html
Microsoft aren't shipping the source standard label translations with the developer boxes. You only get the source for labels in en-us and the rest you only get as binary.
Here is what you can do if want to figure out how a particular labels is translated.
First find the binary for the translated label file. This will be in the Resources folder under the package in question. For example, looking for the PRO labels from ApplicationSuite in Danish:
And next, open the dll in a tool allowing you to peek inside dll's. For example .NET Reflector.
palleagermark: Merge externally modified label files Blog bot DAX Blogs 0 01.06.2017 11:11
palleagermark: Use tags to find related bits and pieces in your code base Blog bot DAX Blogs 0 19.05.2017 12:11
palleagermark: Moving label files between models in AX7 Blog bot DAX Blogs 0 20.07.2016 15:11
palleagermark: Quick import of new label files Blog bot DAX Blogs 0 01.07.2015 12:11
emeadaxsupport: How label flushing works under the hood Blog bot DAX Blogs 0 17.08.2010 16:05
Часовой пояс GMT +3, время: 09:42.
