Старый 16.05.2008, 17:15   #1
In C/Front for Microsoft Dynamics NAV Version 5 SP1, it is no longer possible to initialise it in the usual way from Visual Basic. Often you would initialise C/Front like this:
Dim CFR As Microsoft.Navision.CFront.CFrontDotNet
CFR = New Microsoft.Navision.CFront.CFrontDotNet
But with SP1, this syntax will give you the following error in Visual Studio:
Error 1 'Microsoft.Navision.CFront.CFrontDotNet.Private Sub New()' is not accessible in this context because it is 'Private'.
This way to initialise C/Front was removed because there were various problems (mainly with memory corruption) when disposing C/Front. So to stabilise it, the public constructor of CFrontDotNet was removed. Now, initialise it like this instead:
Dim
CFR = Microsoft.Navision.CFront.CFrontDotNet.Instance
i.e. don't use "New", and add ".Instance". The functionality remains unchanged.
Lars Lohndorf-Larsen
Microsoft Dynamics UK
Microsoft Customer Service and Support (CSS) EMEA
These postings are provided "AS IS" with no warranties and confer no rights. You assume all risk for your use.
Читать дальше
Часовой пояс GMT +3, время: 06:19.
