Старый 17.03.2016, 01:15   #1
organicax: Setting up a demo user to access your new Dynamics AX instance
Источник: http://organicax.com/2016/03/16/sett...s-ax-instance/
If you have a deployment of the new Dynamics AX and you are also an administrator of your Azure subscription or could work with an admin, then one of the things you can do if you need to setup demo users is to create your own Azure Active Directory (AAD) and then create users in there.
Here is a quite overview of creating the user and adding them into AX once you have your demo AAD created.
AX Build 7.0.1265.3015
Cheers
Lachlan
Filed under: Infrastructure
organicax: User preference for date, time and number format in the new Dynamics AX Blog bot DAX Blogs 0 15.03.2016 23:11
crminthefield: Podcast and Overview: Microsoft Dynamics CRM 2011 Update Rollup 16 Blog bot Dynamics CRM: Blogs 0 23.01.2014 03:15
crminthefield: Podcast and Overview: Microsoft Dynamics CRM 2011 Update Rollup 7 Blog bot Dynamics CRM: Blogs 0 27.03.2012 02:11
dynamics-ax: Official Details about Dynamics AX '6' released, including comments from Microsofts Kees Hertogh Blog bot DAX Blogs 0 11.01.2011 05:22
Часовой пояс GMT +3, время: 12:02.
