emeadaxsupport: A few performance considerations for Multisite activation in MS Dynamics AX 2009 SP1
Источник: http://blogs.msdn.com/b/axsupport/ar...-2009-sp1.aspx
============== If you want to upgrade to any MS Dynamics AX 2012 version (R1, R2, or R3) from MS Dynamics AX 2009 then it is a needed requirement to run the multisite activation on the MS Dynamics AX 2009 side as a prerequisite. The multisite activation process is known to be a quite performance intensive task! Therefore I just like to recommend the following tips for the environment where you run the multi site activation: Tips: * Make sure that you run a distributed installation where the AOS server and SQL servers run on different computers * Make sure that the AOS server and SQL server run 64 Bit Windows operating systems instead of 32 Bit Windows operating system due to enhanced main memory handling * If possible prefer physical hardware for the AOS and SQL server instead of virtual machines if possible * Check that “High Performance” under Control Panel, Power options is set for the AOS server, SQL server machine and AX client computer. You may find more information about the setup / background of the “High Performance” setting here: http://blogs.msdn.com/b/axsupport/ar...r-options.aspx * Make sure that the CPU clock speed of AOS and SQL server computer is >= 3 GHz Addtional information: You can find more application related background information in the MS Dynamics AX 2009 multisite activation white paper here: http://www.microsoft.com/en-gb/downl....aspx?id=12840 Some upgrade related information about MS Dynamics AX 2009 multisite activation can listed here: http://blogs.msdn.com/b/axsupport/ar...e-process.aspx Источник: http://blogs.msdn.com/b/axsupport/ar...-2009-sp1.aspx
