Старый 31.01.2015, 23:11   #1
emeadaxsupport: Item cost not updated after posting Purchase Order Invoice.
Источник: http://blogs.msdn.com/b/axsupport/ar...r-invoice.aspx
In case of that you've go through the following symptom where the item cost is not updated as expected after posting Purchase Order Invoice, this occurred with the following scenario.
After creating the purchase order and confirming it with specific Financial Dimensions in the purchase order line, then change the Financial Dimension and re-confirm the purchase order.
Please note that the financial entry, is still consider the removed financial dimension
There is a hotfix have been released for this symptom in Microsoft Dynamics AX 2012 R3 RTM - KB2974637, there more information about this hotfix in Microsoft Dynamics Lifecycle Services - LCS under issue search.
"Note: The hotfix will correct the future of the system behavior, and will not correct the historical transaction. It should be corrected from application transaction whether "inventory adjustment for on-hand quantity, or transaction adjustment"
emeadaxsupport: Why Purchase order invoice did not post any transaction on the balance account for Accounts payable Blog bot DAX Blogs 0 06.09.2012 04:43
emeadaxsupport: Can't find the packing slip during invoice matching or is the invoice form not showing any order lines? Blog bot DAX Blogs 0 11.06.2012 22:13
dynamicsaxtraining: Create purchase order Blog bot DAX Blogs 0 14.12.2009 14:05
Часовой пояс GMT +3, время: 16:43.
