emeadaxsupport: Setting a limit for MS Dynamics AX 2012 RAM consumption?
Источник: http://blogs.msdn.com/b/axsupport/ar...nsumption.aspx
============== Have you come across this question already: Is there an AOS server configuration setting available that might limit the AOS memory consumption? Here comes the answer for you: Yes, there is an AOS server setting called “MaxMemLoad” (http://technet.microsoft.com/en-us/l.../aa569637.aspx ) where you can limit as a percentage value. Example: If you set this value = 80 and you have 10 GB of available RAM from hardware perspective then AOS server would not consume more than 8 GB. Источник: http://blogs.msdn.com/b/axsupport/ar...nsumption.aspx
За это сообщение автора поблагодарили: Logger (1). |
