Старый 15.04.2014, 15:11   #1
atinkerersnotebook: Restrict Field Access By Security Role
Источник: http://atinkerersnotebook.com/2014/0...security-role/
Originally posted on Dynamics AX Tip Of The Day:
The roles within Dynamics AX are pre-configured to restrict users from accessing areas that they usually don’t need to use, but you don’t have to stop there. You can tweak the security even more by restricting access to the field level data that shows up on the forms through the security role maintenance feature, allowing you to give people read only access, or not even show the field in the case of sensitive information. As an added benefit, if you restrict access this way, then the users will not be able to access the data through the reports, or through the Excel add-in.
If your users are already paranoid that they don’t see all of the data, then redacting access this way may push them over the edge.
View original 307 more words
atinkerersnotebook: Using Vendor Requests to Manage On-boarding New Vendors Blog bot DAX Blogs 1 22.10.2013 02:24
atinkerersnotebook: Using PowerPivot to Analyze Dynamics AX Data Blog bot DAX Blogs 1 05.10.2013 07:23
atinkerersnotebook: Using Service Management to Track Service Orders Blog bot DAX Blogs 1 25.08.2013 19:16
Inside Dynamics AX 4.0: The Security Framework Blog bot DAX Blogs 0 31.10.2007 11:40
Часовой пояс GMT +3, время: 13:26.
