Старый 23.01.2014, 19:11   #1
workflowax: AX2012 – On Reassign: Failed to create a session
Источник: http://workflowax.wordpress.com/2014...ate-a-session/
When trying to reassign a record via workflow history in AX2012 we received the error: Failed to create session; confirm that the user has the proper privileges to log in to Microsoft Dynamics.
The cause of our problem was a faulty CIL. We performed a full CIL compile, restarted AX and then were then able to perform the re-assign
Dynamics AXBR: [AX2012] Erro: Failed to create a session; confirm that the user has the proper privileges to log on to Microsoft Dynamics. Blog bot DAX Blogs 0 30.05.2013 06:13
Axilicious:AX2012 R2 : DB Sync – Failed to create a session Blog bot DAX Blogs 0 27.02.2013 21:11
Failed to create user session on the server Serj187 DAX: Администрирование 2 07.06.2011 14:34
workflowax: Workflow Session at Dynamics AX 2012 Technical Conference Blog bot DAX Blogs 0 08.02.2011 18:11
Failed to create user session on the server monk DAX: Администрирование 5 01.09.2009 12:16
Часовой пояс GMT +3, время: 06:25.
