Старый 13.01.2014, 16:11   #1
emeadaxsupport: Dynamics AX 2012 Enterprise Portal: range on dataSetLookup()
Источник: http://blogs.msdn.com/b/axsupport/ar...setlookup.aspx
As described here Configuring the Lookup for a Data Set Field [AX 2012] you can change how lookup look like. What you can also do you can range to the lookup to show i.e. only rooms which are in service. Following X++ shows how to achieve this:
void dataSetLookup(SysDataSetLookup sysDataSetLookup)
List list = new List(Types::String);
Query query = new Query();
QueryBuildDataSource queryBuildDataSource;
QueryBuildRange qbr;
// Add the table to the query.
queryBuildDataSource = query.addDataSource(tableNum(FCMRooms));
// Specify the fields to use for the lookup.
list.addEnd(fieldStr(FCMRooms,RoomName));
list.addEnd(fieldStr(FCMRooms,RoomType));
list.addEnd(fieldStr(FCMRooms,InService));
// Supply the set of lookup fields.
sysDataSetLookup.parmLookupFields(list);
// Specify the field that is returned from the lookup.
sysDataSetLookup.parmSelectField('RoomName');
//add the range
qbr = queryBuildDataSource.addRange( fieldnum(FCMRooms, InService));
qbr.value(NoYes::Yes);
//if we don’t want user to be able to change range we need to lock it
qbr.status(RangeStatus::Locked);
// Pass the query to the SysDataSetLookup so that the query is used.
sysDataSetLookup.parmQuery(query);
We need to lock the range in order user is unable to change the range. Otherwise if user in search will specify RoomName “Cubicle 8” (when inService == No) it will still appear because the range will be simply overwritten.
emeadaxsupport: AX Content: Make Microsoft Dynamics AX 2012 yours! Blog bot DAX Blogs 0 01.10.2013 00:12
emeadaxsupport: Enterprise Portal in Microsoft Dynamics AX 2012 R2 now supports SharePoint 2013 Blog bot DAX Blogs 0 19.04.2013 20:13
amer-ax: Enterprise Portal is Not Working on Dynamics AX 2012 Hyper-V Image Blog bot DAX Blogs 0 17.11.2012 11:12
kamalblogs: Dynamics AX 2012 Enterprise Portal Development Cookbook Blog bot DAX Blogs 0 13.07.2012 09:11
emeadaxsupport: Dynamics AX 2012: Some problems with setting up Form Authentication for Enterprise Portal Blog bot DAX Blogs 0 24.05.2012 14:11
Часовой пояс GMT +3, время: 04:35.
